Question about Whirlpool GD2SHGX Refrigerator
How do I change the water line on a ED22DQXAN00 Whirlpool fridge?
  • 57 Answers
Waterline in the door? Waterline from watervalve to icemaker? Waterline to refrigerator?
Posted on Mar 30, 2011
  • ernie_gamrot Mar 31, 2011
    How do I change the water line in the door?
  • Greggmark1 Apr 01, 2011
    Unplug unit. Disconnect waterline at bottom of freezer door. Remove dispenser cover using flat screwdriver. Two slots at bottom of dispenser cover or two screws under where cup is set. Unplug dispenser cover. Remove assembly that holds switches. Move to the side. Remove 1/4 inch screw holding waterline mount. Pull waterline up and out. New line will go back in fairly easy.
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
Change water line
I think there is a panel that need to be removed on the back of your model.
Appliance 911 Sea Breeze
Aug 02, 2015 | Whirlpool Refrigerators
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
Hot point refrigarator changed leaky water valve. now wont get water out of dispenser. turned water on double checked all connections. bad valve?
It seems problem in this fridge could be related to many issues as each must be explored and could be water filter problem or problem might related to water line problem such as creased line or clogged line or damaged water inlet valve or water dispenser control switch on front of fridge
Dec 06, 2013 | Whirlpool GD2SHGX Refrigerator
I changed the water filter in my Whirlpool refrigerator, model #EDVHEXVQ01. I then tried to reset the filter light, but it did not work. Should I do something different to reset it or did I do something...
Hi
I guess you changed the filter with the fridge plugged in, you need to switch off and unplug the fridge, switch off the water. Then switch on the fridge and bleed the water line for 5 second intervals every 5 seconds for 1 to 2 minutes.
That should solve the problem
Regards
Gordon
Apr 20, 2011 | Whirlpool Refrigerators
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My new Whirlpool Refrigerator the water and ice still stink
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser on our Whirlpool fridge freezer seems to get an airlock from time to time and the water is dispensed noisily and in spurts! Any clues?
TRY AND REMOVE THE PIPES THAT LINK THE WATER TO THE FRIDGE AND REMOVE THE AIR IN THE LINE ALSO THAT CAN BE CAUSED THROUGH THE MAIN WATER LINE TO YOUR HOUSE.
GOOD LUCK.
MOAHMED
Sep 19, 2008 | Whirlpool Refrigerators
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Jul 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
201 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
