Question about Sewing Machines
Need Parts for an older Baby Lock Serger
I have an old Baby Lock Serger that needs a part for the air threading lower looper (inside the machine). I have searched online and can't find a description anwhere of it. Can you tell me where I may find this part to fix my machine? I bought it used, and it is missing one of these tubes or hoses, whatever it's called. My sister has a machine just like it and we know what it needs, but don't know where to get it.
  • 24 Answers
Contact Steve at www.stevessewandvac.com they have alot of parts machines they can help.
Posted on Aug 13, 2008
PRO LINE BABY LOCK SERGER, BOTTOM LOOP TOO LOOSE.
Make sure the lower looper thread is seated properly in the tension disk. (RAISE the presser foot. Grasp the thread between the thread tree and the tension disk and with the other hand, grasp the thread below the tension disk and give a little tug.) When threading, always RAISE the presser foot so the tension disks are released.
If the lower looper thread is still too loose, set it to a tighter setting until it creates the stitch you want.
Feb 27, 2016 | Baby Lock Sewing Machines
Thread tension on a Baby Lock BL90
I suggest changing both needles
and rethreading the machine
use a can of air that is used for computer keyboards on the inside
here's a link for parts to the machine and also has a manual
the manual should have information about the thread tension
http://www.sewingpartsonline.com/babylock-BL90-serger-machine-parts.aspx
Oct 29, 2012 | Baby Lock Sewing Machines
Where can I get a manual for bernette fun lock 006D
Serger manuals for early machines are really basic.
Thread in order.
upper looper, lower looper, right needle, left needle. (see the inside of the looper cover door.)
Adjust tensions to suit the fabric you are sewing.
If you need to change colors clip threads near the spools and tie on new spools to previous threads and draw threads through an already threaded machine.
Bernina is the brand. But I believe early models of the serger were made by Juki. I've looked for the manual for 006 as well and found thinging. Your only other choice is find someone who has one for sale and ask for a scanned copy.... or order a new one from Bernina or one of the other places that has one.
Aug 06, 2012 | Baby Lock Sewing Machines
Threating lower left looper on baby lock eclipse
it's possible that a part in the serger is broken or damaged it need to be serviced by a sewing machine repair shop
Jan 24, 2012 | Baby Lock Eclipse Serger
Lower looper lever will not move to the left side
if a part is worn or damaged or broken it's not going to move
it need to be checked at a sewing machine repair shop
Where is the upper looper on Baby Lock Eclipse model DX
This is what an upper looper looks like http://www.tradekey.com/selloffer_view/id/3755146.htm
It is the one in the back and point toward the needles.
The looper in the front is the lower looper and points away from the needles.
Open both doors on the front of the serger and you will see the loopers to the left of the thread ports.
Mar 28, 2010 | Baby Lock Eclipse Serger
I need a replacement manual for Babylock Xscape BL66
You will need to contact a BL dealer to order a manual, if any are available. This model has been replaced.
There is a threading guide in on the inside of the door on the front of the serger.
Raise the presser foot and set the tension controls to zero.
Turn the handwheel until the upper looper (curved looper) is at it's highest point - there may be a mark on the side of the serger and handwheel for aligning to this point.
Thread the upper looper first, then the lower looper, then the needles.
Pull the threads under the presser foot and to the left side of the serger.
Set the tensions back to 4 - 6 setting, lower the presser foot and stitch a chain before serging fabric.
You may be able to find a free manual download at the Brother website for a similar product.
Feb 20, 2010 | Baby Lock Sewing Machines
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
The order in which to thread the serger
Your serger should be color coded for threading. Just do one at a time either left to right or right to left with the cones. And you should be all set.
Apr 19, 2009 | Baby Lock Eclipse Serger
Lower looper
If your lower looper is not catching the needle thread it needs to be timed by an experienced technician. Not for the faint of heart or one without a service manual.
Sewman7
Jun 05, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
89 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
