Question about Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator
Very loud noise could be a fan , when I open the freezer door it stops. Noise is not continuance, maybe 2 or 3 times every few days. very ignoring sound. Can I fix myself and how?
  • 132 Answers
Well done.
You have spotted the problem staight up.
The fan is hitting on a build up of ice from the freezer.
The defrost cycle is the problem.
There is nothing to do but call a technician in to sort out the defrost cycle fault
Posted on Apr 01, 2011
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
