Question about Acer Aspire M1641-U1521A PC Desktop
No output to monitor ,have tried diff video card no diff,tried removing memoryy from dim 2 then dim 1 still no diff, tried removing battery for 30 secs then refit still no diff ..Any Ideas
  • 1,179 Answers
I am sorry to say that your computer mainboard may be the problem.
I will need to look for leaked or blown capacitors.
Go through my published guide, it is entitled, My Computer is not turning on!!! Is it dead!!! No POST!!!
Be sure to clear the BIOS/CMOS, it is also worth replacing the BIOS/CMOS battery with a new one as it could do the trick.
Thanking you!
damnor01
Posted on Mar 31, 2011
Monitor turns on but there is no signal. Everything is connected
only thing u can try is maybe somehow monitor and pc are on diff settings take out cmos battery reset bios otherwise video card if u have one is dead or monitor one or other
Feb 26, 2017 | Computers & Internet
No signal found when extending to third monitor
Normal PC supports 2 monitors with diff vga output.
Make sure you have enough graphics card to support
Oct 29, 2013 | ViewSonic Computers & Internet
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Feb 03, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
I have an HP the monitor doent turn on but all the light are on how can i fix it.
1. unplug the monitor from the computer and check if you can see the monitor selftest (you will see diff color bars moving around) if you see the monitor self test then your monitor is working fine
2. check the cables. use a diff cable to connect your monitor to the computer. use a known good cable.
3. plug in your monitor to diff computer if it worked then you have to reseat your video card
(NOTE : before removing any internal parts from your computer. your pc must be off and the power cable is removed, after removing the power cable press the power button for about 5 secs to remove any electro static discharge)
4. after reseating the video card and still doesnt work remove the video card from the computer. use the onboard video card if you have one.
if it does work then the video card needs to be replaced.
you can also try to reset the memory by removing them and reinstalling them inside the computer
hope this help
Sep 07, 2010 | Computers & Internet
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Monitor comes on a boot then goes black
check video card it may be going out
Jul 08, 2009 | Computers & Internet
Intel D945GTP monitor going into standby, cpu fan runnning full blast
your cpu might be overheating..it might be defective..if you have no video output it means ur ram or your cpu is bad
Oct 28, 2008 | Intel D945GTP Motherboard
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Monitor picture blurs out and dimming
Hey there chel wjd, My first guess is that your video card is faulty. I suggest you pull it and return your video connection to the onboard port. Ensure you make the necessary setting changes in the bios. If this solves your problem, get yourself another video card. Good Luck!
Jan 31, 2008 | Gateway FPD2275W LCD Monitor
Video output gone
try one ram stick at a time.. also i hope u dint have too much static. that kills memory chips like the ones on video cards or motherboards.
Nov 07, 2007 | Dell (7933E) Graphic Card
Acer Aspire M1641-U1521A  PC Desktop Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
