Question about Whirlpool ED5GTNXMQ Side by Side Refrigerator
I have a model ED5KVEXVB00 that I purchased August 2009. Have replaced water filter twice. The most recent replacement was late January this year which makes it about 2 months old. It has been leaking for about 1 month. The water is driping from the filter enclosure. Could this be a faulty cartridge or some other problem?
  • Harold Beauvais Apr 04, 2011
    I operated refrigerator 3 days without a filter and there was no leak so I replaced the "O" rings on the filter cartridge, lublicated and reinstalled today (4/3/11). Will let you know if it still leaks.
  • 5,370 Answers
There is probably sediment on the housing o-ring or the o-ring is damaged or not seated properly. You can usually use non-toxic grease to lubricate the o-ring and the threads on the housing.But if the fitting is intact and o-rings are not damaged, then yes it can be faulty cartridge.
----------also carefully press the filter fitting hard and see, if there is still the water dripping.Also re-check the filter fitting.If its dripping water from the water line and not the filter side.If the line is dripping, then there can be hairline crack in water passing line.Also check water valve.-----------If all checked ok, then it can be cartridge issue.------------
check out.keep updated.Thanks.Helpmech.
Posted on Mar 30, 2011
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
I have a chevy traverse 2009. The power tailgate wont stay up on the strut. it was working fine the day before. the gate opens to the fully open position before slipping resulting in the gate closing
It's now a recall item. See below.
NHTSA CAMPAIGN ID Number: 15V415000
Component: STRUCTURE:BODY:HATCHBACK/LIFTGATE
Manufacturer: General Motors LLC
Potential Number of Units Affected: 686287
Year: 2009
Make: Chevrolet
Model: Traverse
Manufactured
to: 2012-02-29
Recall Date: 2015-06-30
Summary:
General Motors LLC (GM) is recalling certain model year 2008-2012 Buick Enclave vehicles manufactured January 3, 2007, to February 29, 2012, 2009-2012 Chevrolet Traverse vehicles manufactured July 6, 2008, to February 29, 2012, 2007-2012 GMC Acadia vehicles manufactured September 15, 2006, to February 29, 2012, and 2007-2010 Saturn Outlook vehicles manufactured August 17, 2006, to March 18, 2010. The affected vehicles, equipped with the power liftgate option, have gas struts that hold the power liftgate up when open. These struts may prematurely wear and the open liftgate may suddenly fall.
If the open liftgate unexpectedly falls, it may strike a person, increasing their risk of injury.
GM will notify owners, and dealers will update the software for the power liftgate actuator motor control unit so that the motor will prevent the rapid closing of the lift gate, free of charge. Owners were mailed interim notices on August 3, 2015. Owners will receive a second notice when remedy parts become available. Owners may contact Buick customer service at 1-800-521-7300, Chevrolet customer service at 1-800-222-1020, GMC customer service at 1-800-462-8782, and Saturn customer service at 1-800-553-6000. GM's number for this recall is 15240.
Jan 01, 2013 | 2009 Chevrolet Traverse
2009 altima doesn't recognize key all the time
Nissan been having some problem with key FOB, they don't wont to acknowledge it cause it will turn into a RECALL expensive fix for them.
Sep 21, 2012 | 2009 Nissan Altima
RE: R/O system. Model # PNRQ20FBL Serial # TM30938P This system was in our home when we purchased it in Aug, 2009. The home was less than a year old - so the system was...
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
Feb 28, 2017 | General Electric Profile Smartwater Ultra...
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Bought strada 1.2 new in 2006 Problems: 1.Drivers seat replaced 2009; new seat broken again 2.Clutch replaced on 35 000km. 3. Rev counter replaced after three attempts to...
think you had a friday night monday morning one ,some of the problems are of your own making though ,clutch?? drivers seat broke twice ,how much do you weigh ?? do you like a big mac ?' ,water pump ?? and it went a month later was it fitted correctly first time ,wiring problem with fuel injection was it damaged when changing water pump by taking engine mounting off and jacking up engine ?? .but some of the other problems are not of your making though like the speedo or radiator ,just a friday night monday morning car and i see them on all makes ,try a seat next time ,lot better build quality
Sep 04, 2010 | Fiat Strada Cars & Trucks
My Whirlpool side y side refrigerator purchased last year august is not dispensin water but making ice. I have replaced the filter but still not dispensing water.
there iis a switch on the door dispenser that operates when you slip your glas up for cold water and in doing this you should hear a click from the solinoid when this part of operation takes place
if no noise then probable the solinoid is faulty
if there is a noise then disconnect pipe going up inside of door which in toe kick area try pushinhing on switch to operate if no water comes out remove filter and try again, water should come out where the filter is situated
if no go replace water valve
Nov 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Whirlpool ED5GTNXMQ Side by Side Refrigerator Logo
231 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
