Question about E-Machines eMachines Desktop PC
I just brought an emachine computer and i discovered that it doesnt have microsoft works word processor, i thought all computers came with it.
    Genius:
  • 1,288 Answers
Some do and some don't, depends on the bundling arrangements that the manufacturer made with Microsoft.
I DO suggest you try "Open Office", it is free and as good as works
You can get it here:
http://download.openoffice.org/
Posted on Mar 30, 2011
Why is my eMachines EL1360G processor overloading?
Without knowing the specs on your computer, I would say that the problem is not your CPU (processor) or Firefox but possibly several reasons:
>If you are streaming hi definition video your integrated graphics processor is inadequate for processing the video. You are getting what is called "dropped frames", which means that the video card (probably part of your motherboard as opposed to an independent video card installed inside the computer) is not powerful enough to process the incoming video stream, which means if falls behind in supplying the video;
>You have inadequate amount if memory for doing the video processing since it is being shared with the memory demands needed to run your computer's operating system.
>You have programs or PUP (Potentially Unwanted Programs) adware/spyware running in the background that is interfering with the system (very likely); you need a general system cleanup to get your unit back up to speed. Side thought: do NOT use these popularly advertised "register cleaners" or "system cleaners". People bring their computers to me all the time when these garbage programs trash their system.
>Your internet connection is slow-believe me, this is a hugely common problem.
If you need more help, I hang out at www.suggestafix.com
This is a free computer help forum, post in at the Hardware section.
Jun 29, 2014 | eMachines EL1360G-UW11P
Emachine does not boot both fans are working
Here's a video on how I fixed my emachines boot problem. Almost anything can get in the way of your computer booting. Software, hard drive, RAM, motherboard, processor, etc. Below the video, I attached a link to a tip I made about computer crashes. Computer Crashes and Electrolytic Capacitors
Apr 11, 2014 | eMachines T Computers & Internet
Emachines won't send signal to screen, when turned on it makes one long continuous beep
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
Sep 01, 2017 | E-Machines eMachines Desktop PC
Keyboard wont print screen
Try unplugging your keyboard, restarting your computer and then plugging the keyboard back in.
If there is no change, try updating the keyboard driver by going to "Start" and searching for "Device Manager". Find your keyboard on the list of devices under the "Keyboards" section.
Right click on it and click "Properties" then "Driver" and then "Update Driver"
Apr 04, 2013 | eMachines EL1333G-01w
What's your problem?eMachines D440-1047 what processor have y which motherboard have plis
Here you can see the specs:
http://support.gateway.com/emachines/notebook/2010/emachines/emd/emd440/eMD440sp2.shtml
Processor = AMD V Series processor V120 (2.20 GHz, 512 KB L2 cache, DDR3 1066 MHz, 25 W)
Chipset = AMD M880G Chipset
Jun 25, 2012 | E-Machines Computers & Internet
I have 2 e-machines same year same version different model numbers can i use the same recovery disk on both
Theoretically, yes, but there may be caveats.
Intel components won't play well with AMD and some wifi cards want to balk at 'catch-all' drivers. However, if both your machines have a restore partition on the hard drive, then your idea will work just fine as the restore disk you have is just the install driver and boot sequence for your computer to use the restore partition.
Hope that helped...
Oct 25, 2010 | Computers & Internet
My computer wont boot up the power light comes on,the speakers come on but the keyboard doesnt come on and nothing to the monitor...oh by the way its an emachines w3506
If the keyboard doesn't briefly light up the Caps Lock, and Numlock keys, when first starting the computer, and there's no video signal to the monitor, (No Signal), the computer isn't working.
Suspect the Power Supply first.
Bad Power Supply, is one of the most leading causes of computer failure.
This is brought about usually by one of two things, or a combination of both.
1) eMachines are Budget line of computers. Cheap quality parts are used, to defray the cost of making the computer.
One of the cheap hardware components is the Power Supply.
2) Computer is dirty inside, as well as the Power Supply.
The hardware components inside a computer, as well as the Power Supply, are cooled by air from fans.
Dirt, dust, etc, cause the cooling capacity of the cooling system, to drop tremendously.
Heat = Wasted Energy.
The Power Supply tries to keep up with the call for power, cannot, and components inside the Power Supply fail.
The Power Supply has a weak voltage power rail.
It may seem that the computer is receiving power, but it isn't receiving enough.
A) ALL the lights use less than 1 Watt of power
B) EACH fan uses 2 to 3 Watts of power
C) A typical Processor uses anywhere from 51 watts to 125 Watts.
Depends on what Processor it is.
The W3506 comes with an Intel Celeron D 352
(Single core processor, that operates at a maximum frequency rate of 3.20GigaHertz. 3.2GHz)
eMachines Support>Specifications>W3506,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3506
Information on the Intel Celeron D 352 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Cedar_Mill-512.22_.2865_nm.29
The Intel Celeron D 352 can use up to 86 Watts, when operating at maximum capability.
This is why it may seem as though the computer is working, but in actuality it isn't.
The Processor isn't running.
No Processor operating, no computer.
No computer, No Signal to the monitor.
No Processor running, there is nothing to make the Operating System work. (Windows XP is one example of an O/S)
No Operating System working, the keyboard isn't going to 'light up'.
From here the diagnoses should be to test the Power Supply, or replace it with a KNOWN to be good, compatible power supply for a test.
[Compatible being the Power Supply has enough Wattage, the correct power cables, and enough of the correct power cables]
The Power Supply can be tested in the computer, with all the power cables disconnected.
Use a multimeter, or a power supply tester.
Example of an economical Power Supply Tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
This gives information on the various power cables used, in a personal computer,
http://www.playtool.com/pages/psuconnectors/connectors.html
Using the multimeter, the Positive (Red) probe is connected to the power wire to be tested, then the Negative (Black) probe is touched to a Ground wire.
There are three main voltages, given out by a personal computer power supply, (All are DC volts),
1) The 3.3 Volt power rail.
Wires that have Orange insulation are 3.3 Volt wires
2) 5 Volt power rail. Red insulated wires
3) 12 Volt power rail. Yellow insulated wires
For 12 Volt power, 11 to 13 Volts is okay. Below 11 Volts it's time for a new power supply.
4) ANY Black wire is a Ground wire.
Questions? Post in a Comment.
May 19, 2010 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
22 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
