How to ink the machine - Office Equipment & Supplies
    Scholar:
  • 118 Answers
1. turn on printer.
2. open the printer.
3. the printer will automatically move the cartridge tray into an easy to access location.
4. replace cartridges.
5. close printer.
Posted on Mar 30, 2011
What is error code -41
There doesn't appear to be any reliable information about an error 41 code for Canon inkjet machines. In a Brother machine it means a knackered printhead, but Canon has a different code for that. I can only suggest sending a message to Canon's web site/help desk to see if they can shed light on it.
Feb 12, 2015 | Canon Pixma MG5220 InkJet Printer
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Streaks through the printed page
Description of Problem 100000013725
The ink is leaking out of the cartridge or ink leaked inside my machine.what should I do?
Description of Solution 200000017618
Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorizedthird party ink and/or cartridges.
If the ink cartridge is new and has not been installed into the machine, please do not install the ink cartridge. Place the ink cartridge back into the ink cartridge packaging and call the Brother Customer Service Department at 1-800-284-4329 for assistance.
If the ink cartridge has been installed into the machine and ink has leaked inside the machine, do not remove the ink cartridge from the machine.
Please contact Brother Customer Service at 1-877-Brother (1-877-276-8437) Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Jul 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
Getting error U043 "The following ink tank cannot be recognized. I have the correct tank. Pixma 520 ...tank # 5 PGBK
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 25, 2010 | Canon PIXMA MP520 InkJet Printer
Do i need an ink cartridge for the fax machine to work and setup
Some brands of fax machines and all-in-one printer/scanner/fax/copiers need the ink cartridge to be present and have some ink in it to perform functions which don't actually require ink.
My dad bought a Brother all-in-one, and he is unable to scan or send faxes unless he replaces an empty ink cartridge first. If you have a Brother fax machine, I'd suggest returning it and buying a different brand. They waste ink on unnecessary cleaning procedures and force you to buy more for stuff that doesn't need ink.
Mar 03, 2010 | Samsung SF-3200 Fax
There's Not Enough Ink on the Drum, Wants me to add more
your ink fingers may need cleaning or replaced. your ink pump may be worn out. you should call a tech
Sep 21, 2009 | Gestetner Copier
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Xerox c2424 melting ink sticks quickly
Do you turn it off every night? Anytime the machine shuts down or has a jam and has to recycle, the machine uses a compressor to **** the ink out of the print head and reloads.
The 2424 is extremely inefficient. I have seen ink sticks used up in as little as 200 pages.
What you can do is be sure the power save is turned off, That the machine is defaulted to Black and that you are not using the enhanced setting to print your normal pages.
Honestly the best way to have that machine is on a maintenance agreement that includes ink in the contract. It is a very expensive machine to operate if you purchase your ink.
Wish I had a better answer but those ink sticks do not last long. Do not turn that machine off at night.
Oct 17, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
11 people viewed this question
jasbo
jasbo
