Question about Panasonic TX-32LXD70 32 in. HD-Ready LCD TV
TV picture is breaking up. Used to work perfectly. Sometimes the fault clears when we switch on the attached DVD recorder. Then the update stations option shows on screen. No matter if we choose yes or no for the update, the picture then goes back to unwatchable. The loft aerial has a booster attached. I have checked all connections and all seem fine including the booster. It is the fact that the TV used to work OK but something must have changed to make this happen. None of our neighbours are experiencing this.
lukster
  • 217 Answers
SOURCE: half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Posted on Feb 17, 2007
SOURCE: No video signal on Toshiba TV
replace the power cable of your toshibal tv from 3 pins to 2 pin type.
this is becuase of the earth of the TV, thats why it is better not to eart the tv.
mohannadhsn@yahoo.com
Posted on Nov 04, 2010
  • 11800 Answers
SOURCE: how do i connect my
No, you plug it in directly in the antenna socket at the rear of the tv.
http://www.avforums.com/forums/attachments/lcd-led-lcd-tvs/12427d1113566868-panasonic-tx32-lxd1-lxd50-scart.jpg
You just need a special connector if you have the australian model, like in the picture above. Otherwise it just plugs in as explained in the user manual. If you need the manual
http://diplo-best.com/314.php?k=2e82a812e1d673595f5f6fcff561ba40&ID=199713&q=PANASONIC%20TX-32LXD1
Posted on Jul 03, 2011
SOURCE: I have a Panasonic DMR-BW780
Ive got this problem too. Anyone found a solution?
Posted on Sep 01, 2011
SOURCE: Panasonic DMR EH50 dvd recorder,used
you can't not play back at 3d tv signal out - panasonic dvr ,ok only in regular hd1080 mode
Posted on Sep 04, 2011
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
How do I , or in fact can I, tune the DVD recorder such that it can see the digital TV stations - all I get at the moment is analogue channels
can you receive digital channels through your tv (if it is a DAB TV)? The reason i ask is that you may not have a strong enough signal to receive digital channels. Try taking the dvd recorder to a friends house and plug it in there to see if it will tunethe stations in. IF it does try it back at yoursto see if it will pick up the channels if it breaks up the picture then you need to upgrade your ariel
Mar 11, 2011 | LG RHT397H DVD Recorder
What would make the t.v have lines running horizontal and not give you a picture
It could be any number of things. Try to use systematic diagnostics to trace where the fault lies. Start at input end of system to find out which bits work and which don't.
  1. Do you get a picture using a video recorder, dvd player, gaming console? If yes the problem is with your tv signal.
  2. Connect a different tv to your antenna / satelite dish /- can you get an analogue picture? If no the antenna (aerial) may be faulty
  3. Does the satelite receiver / digital terrestrial (e.g Freeview) receiver give you a picture on a different tv? If yes it could be either a technical fault with your tv or it needs retuning to the correct stations (enter setup menu and reinstall stations as per user instruction manual)
Feb 23, 2011 | Polaroid 4011-TLXB LCD TV
Can only tape clear pictures on DVD recorder from BBC1/BBC2 EX78E
Are you in the UK? Is the new DVD player compatible with TV in your area?
Some technical details like make and model would be helpful.
Apr 05, 2009 | Panasonic Televison & Video
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
Panasonic TX-32LXD70 32 in. HD-Ready LCD TV Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
