Question about GE DBL333EA Electric Dryer
The dryer runs and runs and runs and the dial never moves from "optimum dry." It is producing heat, though.
  • GE Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. I am using this model number: DBL333EAOWW
There are 2 things that cause the timer not to advance. Either the cycle thermostat or the timer motor.
The cycle thermostat is item 1315 on this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=206905&diagram_id=21330627#d21330627
but is not listed in the detailed items.
This is a close up view and source for the thermostat.
http://www.repairclinic.com/PartDetail/Cycling-Thermostat/771221?modelNumber=DBL333EA1WW
The timer is item 100 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=206905&diagram_id=21330624#d21330624
or here:
http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/877670?modelNumber=DBL333EA1WW
The cycle thermostat is located on the front of the blower housing and can be tested with a stick match and a meter. You remove the thermostat.. Heat the metal face with a match until it clicks and quickly test for continuity. It should only have continuity when it is hot.
There can be a wiring problem also on the thermostat terminals but you would note that during removal of the thermostat.
Thanks for choosing FixYa,
Kelly
Posted on Mar 30, 2011
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Whirlpool imperial 80 won't heat much
That clicking noise is normal. You may have a thermostat problem. It sounds as though it isn't letting the element get hot enough, or cycling the element on/off too often.
May 12, 2012 | Dryers
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
The optimum dry is not working - dbl333eb
they have a sensor it will have a few metal strips inside the dryer. ge usually right by the lint filter. it most likely that or whatever feeds it. the auto dry sensing board or timer. sensor, sensor board or timer. most of time sensor is bad.
Aug 01, 2010 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
The timed dry cycle sometimes does not turn off;
If it continues running beyond the cycle point it probably is no longer producing heat and just tumbling. Eventually there is a heat sensor that is triggered. Mine does the same thing. It is likely the result of the timer going bad, though immediaely not a necessity to fix, in the long haul it will save you utilities.
Dec 07, 2009 | Frigidaire FSE748GF Dryer
My dryer is not getting hot. It comes on and runs but it doesn't blow hot air. If I place my dail on "More Dry" the dial doesn't move from the spot i place it in
if your not getting heat the dial will never move its not getting dry, and your in a sensor circuit.
if you have no heat at all
electric......element
gas...........ignitor
this is where id start
Oct 23, 2009 | Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer not drying clothes
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
GE DBL333EA Electric Dryer Logo
207 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
