Question about Maytag Dishwasher
Why wont water start spraying in the machine . no water comes in
  • Maytag Master
  • 3,053 Answers
Hello, m
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Whirlpool awm 8121 water not coming into machine
Turn off water supply behind machine. Unscrew supply hoses from back of machine. They are screwed into your watervalve. Where they attach there are screens that can become clogged from lyme deposits etc. Use a toothbrush or spray bottle (like a window cleaner spray bottle) to flush the debris. Consider installing new washers in the ends of the hoses (garden hose washers work fine.) Reattach hoses to valve hand-tight. Do not cross thread it, Do not use teflon tape or silicone. Once hand tight tweek the connection 1/4 turn more with pliers. If water still does not enter tub replace vatervalve. If you don't know where to get a valve start new post with full model # and what you need. I will find you one quick.
Hope this helps. Good Luck.
Jan 06, 2013 | Washing Machines
Washer wont wash-no water comes in washer
Your water valve inside the washer is either stuck, no water going to hose or the washing isn't sending voltage to open the valve. Start first by removing the hose. If water starts spraying all over the place turn off the hose and check for a blockage when it connects. Sediment may have clogged the screens there. More than likely a new water valve should take care of the problem. Sometimes sediment can pass through the screen and accumulate causing it not to open causing it to stick when voltage is applied as well.
Jan 16, 2012 | LG WM-2277HW Front Load Washer
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
I have a WFS1273BW front load washer and it is filling up fine with cold water but then it starts spraying HOT water out of the detergent drawer. there are no blockages as the cold water goes in fine but...
try to select on the cold water only.if is the hot water is continues to spray its means the water valve in hot water is shorted and need to replace the new one,call the authorized service center to fix it
Dec 24, 2010 | Washing Machines
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water spraying out
Problem; No water or solution
After taking the unit apart TWICE trying to determine the problem I finally realized that the rubber washer on the bottom of the solution tank had come off the tank. It was stuck in the drain - I pulled it out of the drain and put it back on the bottom of tank. Now the tank could sit down properly on the drain. As soon as I put the tank back on the machine, bubbles came up through the solution in the tank indicating that solution had drained into the system as it was supposed to.
I started up the machine and it worked like new again.
Jun 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Maytag Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
