Question about Kenmore 47752 / 47754 / 47759 Electric Double Oven
I keep getting an F9 . The oven door will sometimes lock every 1.5 hours. The book say turn oven off then on, but I need a permanent solution.
  • Kenmore Master
  • 3,361 Answers
F9 is a defective door latch switch.
The complete door latch part must be replaced.
Posted on Mar 30, 2011
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
F9 error message during self cleaning
Dennis the F9 indicates the door lock switch has not positioned correctly. By what you are describing it sounds like the lock mechanism did not pull the door in tight for the cleaning resulting in the code. It's possible it could be a pinched wire on the locking mech. What needs to be done here is that someone has to examine the door lock mechanism to insure it's operating correctly. The door should be pulled tight and the switch sould be closed on the cam. Catriver.
Jul 16, 2007 | GE Profile JT912 Electric Single Oven
LG double oven shows f9 code in both ovens
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Kenmore 47752 / 47754 / 47759 Electric Double Oven Logo
74 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
