I'm using a Burdick 48-hour holter monitor, and when I changed the battery after 24 hours, it won't restart. It simply says my name, STAT #2011-03-29, data not analyzed. What can I do to restart the clock to complete the next 24 hours?
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
T-Mania
  • 42 Answers
SOURCE: HDTV as pc monitor-no digital signal
Try different Resolutions/DPI and Refressh rates the other possibility is settings on the monitor check the manual of the monitor for use with the pc as in resolution etc.
Newer monitors oftem change there own settings to best suit themselves or act differently if forced to use different settings.
The returning to 16bit seems odd though only other suggestion is trying updated video card drivers from the vendors site.
Posted on Mar 18, 2009
budmrtn
  • 11361 Answers
SOURCE: my monitor goes blank. it comes back after i have
Check for bad caps in the power supply first, look for caps with ulging top, post back what you see so we can guide you further, see example of failed monitors due to badc caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 17, 2010
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
escapement
  • 2334 Answers
SOURCE: Changing from 12 hr to 24 hr on a Casio Data Bank 150
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please ...
Posted on Apr 02, 2010
Placement of electrodes in a 5 piece system, please
Contact the manufacturer. This equipment is specialized and subject to patent restrictions on that info.
May 26, 2015 | Cardiac Science Burdick Vision 5L Digital...
Not cold enough
HI. DEFROST ALL FIRST 24/48 HOURS AND TRY.if it works then check your defrost timer first and then heater and t/stat.then next stage .good luck ali
Jul 09, 2012 | Maytag MZD2667HE Side by Side Refrigerator
I bought a used Maytag refrigerator, model 2254HEW. For the first month or so,it cooled perfectly, now it is taking a couple days to cool soft drinks and then not real cold. The unit is in the garage and...
HI TOM.WELL IF IT WORKED FINE FIRST THEN I SUGEST U DEFROST ALL FOR 24/48 HOURS OR REMOVE FREEZER REAR PANEL AND DEFROST ALL MANUALLY.IF U TAKE PANEL OFF THEN U MIGHT AS WELL CHECK HEATER,T/STAT.AH BEFORE THAT TRY TURNING DEFROST TIMER MANUALY.UNTIL IT CLICKSTOPS.WAIT 1/2 HOUR.SHOULD RESTART AUTOMATICALY.IF NOT THEN THATS YOUR PROBLEM.(LEVE ON OFF POINT FOR AN HOUR OR SO TO DEFROST ALL THE ICE THEN CLICK ON MANUALY AND REPLACE.GOOD LUCK.ALI
Jul 05, 2012 | Maytag Refrigerators
Please my email husin_abdelmenem @yahoo.com as open email appears your account hase been locked i tried to solve the problem to push the password do not work but i do so appears this messageSorry, this...
Actually the problem is with Yahoo, but let me explain why this happened and how to get it back. There's no possible alternatives for you to access your account currently. You have to wait at least 24 hours, this happens when someone or the user attempts to login with wrong password or wrong username several times. Will be able to access after 24 hours, even writing to yahoo support will not helpful since their response takes at least 48 hours which is longer than the time you are gonna wait.
If you want this to be faster, your only option is to wait for 24 hours without any attempt otherwise, it'll reset to 24 hours even if you attempt to login after 20 hours and you'll need to wait another 24 hours and so on, this is not controlled by man, but it's controlled by software.
If in case someone is playing with your account, there'd be problem, suppose if someone tries to login while you are waiting for the 24 hours to get passed, same thing will happen again. Yahoo will not be able to recognize since these things are monitored on the server.
You can try writing to the Yahoo about your problem using this contact form.. Sign-in and Registration help form and all fields without "(optional)" are compulsory.
Good luck.
Thanks for using FixYa.
Jul 28, 2010 | Yahoo Mail
I fully charge the phone but within 48 hours,even without using it, have to charge it again
Don't panic this is quite normal.
Even when you are not using the phone it is still on and actively connected to your service network. Therefore using battery power.
Actually to get 48 hours from your handset is very good.
Normally you would have to re-charge the 81xx series at least every 24 hours.
I was charging mine every 12-14 hours.
Jul 27, 2010 | RIM BlackBerry Pearl 8100
We move my refrigerator and it was laid down for about 2 hours we plug it up when we got home now it won't get cold, how long will it take to start getting cold it been about 2 days now
It shuld never be layed down for transport or storage. 2 Hours is not a long time but you should have left it upright overnight before plugging in. turn it off for 24 hours. When you restart it it should be cooling in a few hours and at normal temp in 24-48. If not you may have damaged the compressor. (Assuming you hear it running)
Eric
Dec 23, 2009 | Kenmore Refrigerators
Dropped mouse in water
You will need to remove the batteries and let it dry for 48 hours. Having the batteries in the mouse while there is still potentially some water in it will damage the the electronics inside (if they are not already damaged) If after the 48 hour period your mouse still acts funny then you should simply replace it.
Sep 17, 2009 | Computers & Internet
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Roxy 80' W056DR
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
Apr 11, 2008 | Timex 1440 Nylon watch
Unlocking Mac 0s 9
yes all you need to do is remove the internal battery for 24 hours this will clear the memory and you should beable to use the pc and no you won,t lose any programs
Feb 23, 2008 | Dell Dimension 4550 PC Desktop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
