Question about Sony Televison & Video
Sony KP-46WY510 Picture has color ghosting. Images about 2 inches offset from each other in red, green and blue. Picture is also coming up in the bottom center and down in the top center. Kind of an arc across the top and bottom. Any ideas? Thanks, Glenn
  • glenn571 Aug 04, 2008
    Not an rf problem. Happens even on graphics such as the volume bar. Juat looks like it's way out of convergence. About 2 inches at the sides. Almost ok in the center.
    Glenn
  • Sony Master
  • 19,396 Answers
If you are using a cable or satesslite receiver chgeck that the problem is not the connection withthe receiver.
Posted on Aug 04, 2008
  • Ginko
    Ginko Aug 04, 2008
    Try also to set the convergence using the flas=h focus button, see
    How to fix convergence problems using Flash Focus
  • Ginko
    Ginko Aug 05, 2008
    Are the mirror tubes. If you get displaced green images, for example, it is the green tube needs alignment, this is a frequent problem with your model.
    If is not a tube alignment matter, then is a broken component, probably an IC or a capacitor has blown. A technician must test the pcb inside in both case.
    Chech if your TV is under guaranty, if not check with Sony if you can get an extended guaranty, it cost $300, and usually repay itself at first use. Do not mention the fault when asking extendend guaranty.
    You find Sony customer service number printed on last pages of your user manual.
Why does my sony 45 inch screen have mostly green color?
the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
Picture ghosts shows 3 images like it is out of focus colors also ghost in 3
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 01, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57WV600 different colored images red,
Ur convergence is dying,well be dead soon.These problems cause byconvergence.Blurry coloring,3D images or misaligns colors.Repair this must replaced 2 convergence ICS and all it resistors.The shop well cost U 300 for parts and labors.
Feb 09, 2010 | Sony KP-57WS500 57" Rear Projection...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
