Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
PANAFAX UF880 - no power
I cannot get the machine to respond when I turn it on. Is there a fuse somewhere, or do I need to replace the power supply? No manual found.
This issue is under the wrong topic area. I have started another issue under the proper topic. Please ignore this thread.
Posted on Aug 05, 2008
We have a whirlpool AWM6140/3 1400 spinspeed when I turned machine on it fused the supply at the fuse box not the plug,now it won't turn on
hello because there a dead short somewhere the fuse inside the washer power supply could have blown if this ok you will need to check wiring if ok then there could be a fault with the power supply board hope it helps
regards
shaun
Jan 08, 2011 | Whirlpool AWM6140 Front Load Washer
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panafax UF-895 - keyboard dead
cracked keyboard from a heavy hand. Will need a tech to replace.
May 05, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
My HP Photosmart C4480 will not turn
If you are confident with electronics, remove the rear casing near the power socket, and check the power supply board for a fuse. Using an exact match, replace the fuse and replace the cover. Try powering up. If it fails, you have a blown power supply :(
Mar 05, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF-6000 can send but not receive
Yes, especially if they were active.
Do they show Code 21?
Factory reset them.
Unplug the power cord from the back of the machine
While holding down the ENERGY SAVER key, plug in the power cord.
Scroll down to SHIPMENT SET
press SET
press 2
wait for machine to reboot
Oct 16, 2008 | Panasonic PANAFAX UF-6000 Fax
Time and Date
1) select function #7
2) select #1
3) select "set"
4) enter the new date and time (MMDDYYY) (1500 - 3:00 PM)
5) select "set" and stop
Apr 15, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
