Question about Refrigerators
How to adjust doors so they will close - Refrigerators
  • 132 Answers
The doors them selves are not adjustable.
The fridge feet have to be adjusted so that the fridge leans backward. This will cause the doors to fall closed
Posted on Apr 01, 2011
How do I adjust the sealing of the door when closing
The adjustment for this is usually on the back or side of the motor unit. Clockwise movement of the screw will lower the door position - keep adjusting till it seals. Do not over seal because then the door will reverse itself as the obstacle circuit might kick in and open the door.
Dec 25, 2014 | Building Materials
The door closes but not firmly their is still movement when fully closed
The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Dec 30, 2010 | Panasonic NN-T551 Microwave Oven
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
Door adjustment for a 96 f350 dropped about 1/2"
Here's the solution: You might want to park it under a tree and tie a rope to the door to pull it up when loosened.
ADJUSTMENT Fig. 1: Door hinge adjustment 84920001.gif
Fig. 2: Rear door hinge adjustment, F-350 Crew Cab 84920002.gif
NOTE: Loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
  1. Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  2. To move the door safely, use a padded prybar. When the door is in the proper position, tighten the bolts to 19–25 ft. lbs. (25.5–34.5 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  3. Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
Jul 13, 2010 | 1997 Ford F350 Crew Cab
Gdm-73 how to adjust the door closing?
there is no spring tension on refrigerator doors,you adjust the front legs slightly higher than the rear legs and this forces a small amount of incline and gravity on the door to help it close on its own
Mar 23, 2010 | Refrigerators
I have a new Sears 315mhz garage door opener and the door fails to reverse when an object is placed under the door
It sounds like the force adjustment may be set too high. Check this:
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Track rail bends when closing the door
I think you need to take the cover off the motor unit and watch the limit switch assembly in operation. Takes only a few seconds to see how it works and see if it is damaged in some way. You need to turn the down limit adjustment in the opposite direction of the arrow printed on the cover to stop the door sooner. I think the down force adjustment on the rear of the motor unit is out of adjustment also. This adjustment affects the safety of the opener and should only be adjusted high enough to consistently close the door.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Whirlpool gd5thgxks01 door does not auto close
You need to level the refrigerator slightly backwards so the weight of the door closes it automatically. The front legs are adjustable, so just turn them until the door closes on its own.
Aug 05, 2009 | Refrigerators
Garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Mar 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
