Question about Kenmore 64802 Top Freezer Refrigerator
Where is drain plug inside refrigerator? - Kenmore 64802 Top Freezer Refrigerator
  • Kenmore Master
  • 8,220 Answers
It's behind the service panel
The copper wire goes down the drain in this instance to keep ice from forming in the drain.
Posted on Mar 30, 2011
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Feb 15, 2015 | Samsung Refrigerators
Leaking inside refrigerator. Model 106.70182000
Yes if it's a top freezer the drain could be plugged or even frozen...there should be a drain line routed to behind the back of the frig. you should be able to access the blockage there.. Good luck
Jun 05, 2012 | Kenmore Refrigerators
Condensate line is plugged,water collects inside
your drain is plugged. water should drain out of freeze into ref. then collect in pan . u just need to find the drain in the freeze. need more help let me know.. ok
Feb 11, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water accumlates inside refrigerator
The defrost drain is plugged up. You must access the evaporation department and open that drain. I have free repair manuals HERE
Jan 19, 2010 | Refrigerators
Leaking in the bottom of the freezer side
Plugged up drain. Unplug refrigerator. Remove basket at bottom of inside freezer ( it may be frozen in ice) . Get your hair dryer and thaw and remove all ice, At the very back bottom of inside freezer is the drain that is plugged up. You will see a hole, pour hot water into it. You may need to snake a flexible piece of wire through the hole. Once water goes down its open. Worst case you may have to remove drain tube in back bottom and clean out. Hope this helps
Refrigerator Repair
Oct 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Water draining to bottom of refrigerator during
you need to check behind the panel on the freezer side (inside) the drain hole is more than likely plugged. run a coat hanger through it.
Aug 26, 2009 | Whirlpool Refrigerators
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Haier RRTG21PAA Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
May 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
