Question about Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale
I am getting a message "L-od" on my scale. Changed the battery and continue to get the same message. What is going wrong? I have ony had the scale a few months.
2 Suggested Answers
r321567499
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
I have changed to batteries twice but I Continue to get error messages. What to do now?
If the batteries are good the hassle has to be with the electronics.
If the pressure sensor is in the on position when booting, that could result in the error message you are getting - make sure it is open when booting up the unit.
Nov 05, 2015 | Homedics SC-405 Digital Bath Scale
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
Message center constantly displays door ajar message
My 2003 exp-eb-5.4- had the door warning going off all the time, sometimes it seemed more rounding a corner to left. Sometimes I would see the lights on in the middle of the night. Sometimes my battery would be dead after setting a couple of days. Then I wondered if battery was causing the whole door ajar security thing. Switched battery and problem solved. Now 3 or 4 months later has started running crappy in OD, will cruise ok if holding throttle steady. Runs better by turning OD off or at higher RPMs.
Feb 10, 2012 | 2003 Ford Expedition
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
Transmission shifts ony 123 no overdrive, it slip in overdrive
sorry to say this trans has to be removed and rebuilt seems like od clutches burnt out-do you tow heavy trailer with truck as you have to tow with od off(push button on shifter)
Oct 05, 2009 | 2001 Ford F150 Styleside SuperCrew
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
ERROR message
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale Logo
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
