Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
I have a Saeco Royal Digital machine and drop water in the container of coffee beans. Now I can not grind coffee. What can I do?
  • Saeco Master
  • 12,061 Answers
Hi, well i am sorry to hear you are having problems with your machine, and with a problem such as you describe, it would seem either the grind motor is faulty, or the controller/sensor that starts the motor is? It's just too hard to exactly isolate from a description as you would no doubt understand.
The very best thing you can do to get it repaired at a reasonable cost, is to contact the Agents, or the manufacturer, for & of, the machine, and ask them for a referral to an authorised service center/person.
Now when engaged with the repairer, first only ask for a "Quote" as to the cost and type of repairs required. This way at least, you can then, make an informed decision as to repair or replace.
Posted on Mar 31, 2011
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Oct 30, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Dec 16, 2007 | Saeco Royal Professional Espresso Machine
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
