Question about B&K CT600
Who repairs or reprograms B&K CT600 series receivers?
My garage door opener opens my neighbors garage door,how do I reprogram mine?
Open up your remote. You're trying to establish if it has dip-switches or if its a modern remote. If it has a series of little switches (black tray with small white pins) then you can move to step 2. If the content of the remote is all electronic then you have to get somebody that specializes in automation to com out & re-program your remove & controller. Step to on the dip-switch solution is to change one of the numbers & corresponding numbers on the receiver. Its less likely though, that your remove will have these dip-switches. Technology has progressed past this elementary coding & its easier to bypass, as well as more expensive, so thing these remotes are mostly, if not all electronically coded. Still a professional can reprogram the frequency for you, but they have to come to you to do it.
Sep 26, 2017 | Building Materials
GE 15136 timer display stopped working
Try resetting timer, and reprogramming.
The GE brand of electronic box timers is not dependable long-term product. The 30-40 amp contact ratings do not appear consistent with rest of timer quality. I think the amp load is overrated from what I have seen, compared with heavy duty timers like Intermatic GM40AVE series etc.
My local home depot has replaced the GE line of box timers with 100% reliable Intermatic T100 series mechanical timers.
http://waterheatertimer.org/GE-timers-and-manuals.html#15136
15136 is not battery-operated timer, and there are no repair parts.
15136 timer is rated outdoors, with temperature range -40F to +130F, which sounds like hardened electronics.
But often these cheaper electronic devices with plastic gears and multi-voltage are not hardened for years of dependable service as found with commercial grade timers.
Nor are they protected from surge caused by local power outage or nearby lightning strike.
For most dependable timer, and cost effective, choose T100 series or T170 series with skip-a-day... repair parts available... timer will last decades
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Gene
h
Nov 23, 2013 | General Electric Hardware & Accessories
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
2001 saturn sl200, odometer stuck 634,578 miles probably closer to 95,000 miles. any idea how to repair?
i can tell you this was a very common problem on the 91-94 S series instrument cluster, so common that an odometer repair kit was sold on eBay for just a few bucks. so you could go look at eBay and see if there is an odometer repair kit for the 00 & 01 S series as I think they were not made after 01 and the 95-99 clusters were different. A search on www.youtube.com always turns up interesting Saturn repair videos.
Apr 20, 2011 | 2001 Saturn L-Series
Remote key is not working
Hello... not sure were the receiver is but the problem is mostly the remote key lost its pairing to the receiver and the receiver itself is good. Check to make sure the batteries are good in the remote key and change them if need be. Then reprogram the key.
Good Luck....
Jun 15, 2010 | 2002 BMW 3 Series
Remote controll not working not
The best thing to do is:
1- Replace the battery that is located on the back of the remote. If nothing happens then;
2- Try reprogramming the remote control with the car. if you have the original manuals, then it will precisly tell you how to reprogram your remote to successfully communicate with the alarm module in the car.
The problem could also be the Alarm module receiver.
hope that helps. Let me know.
May 29, 2010 | 2002 BMW 3 Series
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Jun 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I AM IN NEED OF A USER MANUAL FOR A lAVADORA CT600 WASHING MACHINE IN ENGLISH. THE MANUAL I HAVE IS IN SPANISH COULD YOU PLEASE HELP ME MENY THANKS SANDY
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 03, 2009 | Washing Machines
I have a TX SR 803 av reciever that keeps losing it's audio. I have to keep reprogramming the audio outputs,sometime this works and sometimes it doesn't. Zone 2 is fine. problem began after a power outage
Try to reset your amp then go to the bottom of the set up menu and you should find lock set up,if this dose not work its repair time for your amp.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Onkyo Audio Players & Recorders
B&K CT600 Logo
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
