Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Hi. I have water in the floor by my fridge freezer its starts may be a 3month ago. What are the reasons could be? and how can I repair.
  • 132 Answers
The condesate drain could be blocked. things like peas, corn and mould can do this.
Pour some warm soapy water doun the drain to try and clear it.
The water sould drain out the back of the fridge into an evaporativr drain tray
Posted on Apr 01, 2011
Testimonial: "Big thank you!"
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
Hello. I have this fridge-freezer, but unfortunately I can't remember when it was bought. I guess it must be between 7 and 12 years ago! It's worked fine but a couple of days ago it started making...
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Refrigerators
Ice built up floor of freezer compartment. water on floor
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Maytag MZD2766GES Side by Side...
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
656 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
