Question about ViewSonic Audio Players & Recorders
No sound from V2235WM. How to activate? - ViewSonic Audio Players & Recorders
  • ViewSonic Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 30, 2011
Xp activation code
Install the XP drivers that came with the card. If you don't have them you can download them from the Creative Labs website. There are NO activation codes for sound cards.
May 03, 2014 | Creative Labs Computers & Internet
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
My sound on my laptop is not working
No sound working could be any number of things. In my opinion the most common problem is that the correct speakers are not active. So, go to -
Control Panel>
Sound
And it should show a box with all sound capable devices. Being a laptop, you might have a USB headset, maybe a set of external speakers.. Or just your 'standard' sound which will be named by your soundcard.
Whichever sound source you're trying to use, make sure it is active and enabled. If you don't see the source you want, Right click on any of the devices, and click on 'Show Disabled Devices' and also on 'Show Disconnected Devices'. Again, make sure the one you want to use is active, and maybe set it as default.
You should now have sound :)
Feb 09, 2013 | Toshiba Satellite M65-S809 Notebook
I have a Logitech Harmony 670 remote. The problem I am having is when I want to use the "Watch a DVD" activity, there is no audio. I have audio on all other activities. (I have surround sound). I have...
Changing the settings within an Activity:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks What input does the AV Receiver need to be on, please choose the Input that you herd sound coming from when doing the testing.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Oct 29, 2009 | Logitech Harmony 670 LCD Remote Control
No sound at all, have linux not windows.have sound blaster model ct4170 and am runing utubo 9.04 desktop x386, what can i do myself?
hi richbax,
the soundcard you are currently using (Creative Sound Blaster ct 4170) is supported using the ALSA sound driver/server, you can activate it by:
1- verify the soundcard device is detected properly by issuing a lspci command from the terminal/console or command prompt
user@localhost# lspci
2- if Creative Sound Blaster ct 4170 is listed, proceed by issuing a alsaconf command to activate alsa server to use your sound device
user@localhost# alsaconf
3- then issue a alsamixer command to activate and adjust sound volume
user@localhost# alsamixer
4- press escape key then issue a alsactl store command to save setting and restore after bootup
user@localhost# alsactl store
Sep 27, 2009 | Creative Labs CT4170 Sound Card
Linux driver for Sound Blaster 4170
hi jsimons452,
Jul 08, 2009 | Creative Labs CT4170 Sound Card
Playing the sound of tv through the sound bars speakers
Not sure for the playstation etc, but for the TV the manual says using the (not included) optical link between TV and the main unit.
Note that this is not mentionned in all language versions of the manual.
Apr 10, 2009 | Samsung HT-X810T Theater System
Cannot activate my sound card
You have to install the driver of your sound card. If it is no with you , you can download it from the net by giving the model of your sound card.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 03, 2009 | Computers & Internet
Top ViewSonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ViewSonic Audio Player and Recorder Expert? Answer questions, earn points and help others
