Question about Eiki Office Equipment & Supplies
I have an eiki lc xg400 at my disposal. I have a toshibi vcr/dvd player. How do I hookup the vcr to the projector and is the hook up different for the dvd? Thank you De
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
This depends on the signal type coming from your sources
best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
Posted on Apr 17, 2014
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
SOURCE: the projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Posted on Feb 08, 2009
  • 87 Answers
SOURCE: Our Eiki LC-986 projector has worked flawlessly
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Posted on Jun 15, 2009
RedZone133
  • 25 Answers
SOURCE: consistent flickering; had the projector on for 2
Check your filter and make sure the projector is well ventilated ( all vents free of objects), all electronics have to cool. Some lamps start flickering when their about to die.
Posted on Oct 27, 2009
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
New projector. which cords do I need?
laptop, vga. dvd, composite or s-video, and audio. gaming console, composite or hdmi, if you have it.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Eiki LCSB Projector: no input
make sure the resolution matches the input.
Sep 14, 2008 | Eiki LC-SB20 Projector Multimedia...
RGB HD15 to Component/RCA cord
test with new cabels -and switch on your dvd first and projector second-confirm that projector input in video status(test with good brand cd).
Mar 12, 2008 | Eiki LC-XB20 Projector Multimedia...
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
VCR not recording higher-numbered channels
Yes coming in her VCR with Cable or ant, if she has satellite it would be different. Going out to tv from VCR. Then in is Input the Out is Output. RF cable connection or A/V inputs(jacks) either one same way of hookup.
Sep 15, 2007 | Zenith XBV442 DVD Player/VCR
EIKI LC 300
I use it for my xbox 360 for both streamed movies and those I buy on DVD and to be honest it beats any glass tube you can buy. I have been really impressed with my but I do not like how they justify a 300 dollar price tag for lamp replacements. Just can't seem to figure out why any light bulb would cost more than 20 bucks. But hey maybe I am old fashioned :) YES it's beautiful for movies, course it's the only projector I have watched them with.
Aug 19, 2007 | Eiki Projector lamp Projector Lamp for...
93 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
