Question about Sharp Televison & Video
What are the specs for ST5UF78S (sharp tuner) and CT5800 (RCA tuner), i.e., can i use a CT5800 to replace an ST5UF78S?
32 inch sharp aquos can't find any channels with rca amplified indoor antenna
That could be because the antenna is pointing in the wrong direction, or it's just not getting enough signal where it is in your home.
Have a look at neighbours antennae. See the direction they are pointing. Point yours in the same direction too.
Other causes: you are trying to tune the analog tuner rather than the digital tuner.
Sep 07, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I got my hands of a Sharp Power Amp SX-9800. It has a power cord and a set of RCA jacks (1 red, 1 white) plus two bare wires (no jacks or connectors). It has several speaker outlets. How do I hook this...
Which is it 9860 or 9800? (No web search hits for the 9800).
JVD Tuner?
The RCA jacks on any amp so-equipped are for any external Line Level source like a tuner.
In any 'connection' question there are at least two participants and specific answers require specific details about all joined equipment.
Type carefully if you want good answers.
Sep 23, 2011 | Sharp SX9860 2-Channel Amplifier
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Problem for Sylvania LC195SLX LCD TV Channels will not program in tv.check with different tv it works
It looks like your TV doesn't have a digital tuner in it. Without that you won't be able to receive any broadcast television stations. The spec sheet is here: LC195SLX the tuner is listed as just ATSC/NTSC - not digital. You will need a cable or satellite box to receive stations.
Jun 14, 2010 | Sylvania LC195SLX LCD TV
Sharp tv that sound doesnt work using rca cables the red green and blue wires
do you have sound if you hook up cable to the tuner if so check your wire.
Aug 19, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
Rca d52wi5 tv tuner replacement
i have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Digital Tuner
Most places listed "1 tuner" in specs. Was finally able to find a site where it listed the type of tuner which confirmed that it was not HD compatible. That was all I needed. Sorry I troubled you with this, I shouldn't even have been on your site with this Q. Thanks for responding. Potter1
Apr 26, 2008 | Sharp 20F640 20" TV
Tuner Problem
Robert,
Replacing the "F" connector is usually all that's needed unless the tuner board is cracked. You could remove the tuner - send it in for repair and re-install it... It would clearly save a few bucks!
Any shop should be able to do that one easy enough... Around here we charge $40.00 including the part to replace the "F" connector and there are shops that charge even less...
Bill
Feb 09, 2008 | RCA 20F512T 20" TV
Problems With RCA Television (Gray Screen)
Your problem is the old rca tuner sheild repair thingy. Its a simple but tricky repair where the tuner grounds around the tuner sheild and under the bottom of the tuner sheild has to be resoldered. Most repair shops in the states that i know of charge like 65 to 125 .00 to do this simple repair. Now if you know how to solder you can get this reapir mod from sams photo facts and do it your self but its really an involved thing if you dont know what your doing as some of the serface mounted parts look like a spec of dirt and i've seen a few peeps clean off those specs and ruin the whole set. Best for you to take this set in for a repair. Good luck
May 05, 2006 | RCA F25645 25" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
