Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
Icemaker isn't making ice. However we do have cold water and there seems to be no leaks.
  • LG Master
  • 6,993 Answers
Hi
Investigate each of these two areas if your ice-maker ice;
1. Water Inlet Valve
2. Defrost Thermostat
Water Inlet Valve: Your ice maker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An ice maker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
Follow the below directions to test your water inlet valve;
Before you begin to test your ice maker's water inlet valve, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this test.
1. Locate your icemaker's water inlet valve, it is typically located behind a refrigerator. Gently pull your refrigerator away from the wall. You may want to place scraps of carpet, of some other soft material below the fridge to prevent damage to the floor. Turn of the water valve's water supply by closing the shut-off valve in the waterline leading to the water valve. Remove the lower access panel on the back of the refrigerator using a screwdriver or a nut driver.
2. Place a container under the valve to catch any water that may spill from the water valve and its fill tube. Remove the water valve's fill tubing. Loosen the flare nut on the brass fitting that is found on the inlet side of the water valve. You can use a wrench to loosen the flare nut.
3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nutdriver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
4. There are two wires connecting to the terminals of your water inlet valve. If yours is a double solenoid water valve, it will have four wires. Be sure to label each wire so that you know where to reconnect them later. Firmly grasp the metal connector of the wires in order to remove the wires. You may need to use a pair of needle-nosed pliers. Do not pull on the wires themselves.
5. Set your multitester to the R X 1 ohms setting to test for continuity. Place each of the multitester's leads on a terminal. Your multitester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
6. If the test you conduct with your ice maker water inlet valve does not produce these results, then you should replace the component.
Defrost Thermostat ;
It could just be that your freezer thermostat is not set low enough. Try adjusting the thermostat to a colder setting. Or your ice maker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If it has, you will need to replace it.
Directions for testing a refrigerator defrost thermostat;
Before you begin to test your defrost thermostat, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Follow the above closely and I believe it should guide you in solving the problem;
I hope this helps.
Good luck.
Posted on Apr 01, 2011
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
I have a KitchenAid Side by Side with a stubborn ice maker (modular). It seems to make ice, but it won't complete the full harvest cycle for some reason. I can mess around with it (basically warm it...
Hello Tom,
I see where ya said the water dispenser works good and thats cool! when you do get the i/m to run the ice harvest cycle are the cubes full size? if yes the water supply can be ruled out as a possibility. Besides the water not seeming as cold are other things in the fresh food compartment NOT as cold as they are not as cold as in the past,if yes try removing the grill below the doors and clean the dust from the coil there,if it isn't there its the rear of the ref. by the compressor. One of the first things to be affected when a ref is working hard to keep things cool due to a dusty coil is going to be the icemaker,it will freeze the ice but the internal thermostat inside of the i/m module isn't satisfied its cold enough to start the harvest. When jumping out the T&H what exactly your doing is jumping the t-stat regadrless of the temp. of it ,causing it to run a harvest cycle
I hope this answer helps you,
Gene
Aug 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
My ice cube maker isn't making cubes,but I still get water
hello,
In a case like that usually the problem is going to be a cooling issue, is the fresh food and freezer section both cold? it obviously takes water and freezing tempatures to make ice.
2 things to check are
1) the condenser coil under the grill below door or on back depending on model is clogged with dust and needs to be cleaned
2) the fan in the freezer isn't running circulating air into ff section and directly onto icemaker
Good luck, i hope this helps
Gene
Jul 31, 2011 | Kenmore Side by Side Refrigerator
The icemaker moter activates when we push the lever,the water comes out.the icemaker won,t make ice.Could the white tubing back of the freezer be frozen.Refrige moter when pluged in is noisy.
If water fills the tray them no it isn't frozen. Make sure the freezer is getting cold and that the water is sitting in the tray and not leaking out. What is the freezer temp. put a thermometer in there for 20 minutes. Zero celcius or below and 32 f or below preferably. 33 f won't do it even if it seems cold. Vacuum out coils under fridge and be careful not to tear things up under there.
Jan 28, 2011 | Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
May 07, 2009 | Kenmore Refrigerators
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
120 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
