I need service manual for samsung P1043 washing mashine or technical data for transformer of control block. Thanks in advance. Yours Wigor I.M.
    Brigadier General:
  • 6,277 Answers
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you may either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C.
Posted on Mar 30, 2011
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Cutter grid is not getting hot
I need you to look around your ice maker for a package containing a wiring diagram. I have information related to the Whirlpool 15 inch and 18 inch ice makers but for some reason GE did not publish the repair manual for your model. I want you to check the voltage going into the WR62X10015 Transformer
You should be getting at least 120 volts ac. Then test the voltage coming out of the transformer. What is the voltage coming out of the
WR62X10015 Transformer? Check the control board area for a fuse that goes to the
Check for loose connections going to the grid or broken wires on the grid itself. WR29X10073 Cutting Grid Assembly
Here is a link to the GE Monogram Technical Data
The Whirlpool and the GE Monogram Ice Machines are basically the same thing other than part numbers so I am linking to the Click Here=> Whirlpool 15 inch and 18 inch Ice Machine Service Manual I will be here to answer your questions so please let me know should you have questions, More information can be found
HERE Thanks Sea Breeze
Apr 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
Asko W640 washing mashine !!! Got "engine failure" as an error message on the display and the mashine did not work. I changed the brushes and now the mashine is running until end of the...
You have to change the hose at the top of the drum and you need to polish the commutator in the motor - I removed the motor, took the brushes off, stuck the pulley in my lathe chuck, supported the motor housing and polished the commutator with a little 1200 wed and dry and some wd40 - seems to have fixed the exact same problem as yours.
Jul 25, 2011 | Washing Machines
Samsung tv rest code
in order to reset a locked out TV you must contact Samsung technical support, they are the only ones that give you a override code to reset the lock out. the number is listed in your owners manual.
Mar 19, 2010 | Samsung DLP HL-P5663W 56" TV
I need a service manual for a samsung refrigerator RB1855SL
This manual cover 4 models like yours. If I try to open just the model number I get compressor. By choosing the highest level of the model you have I needed to cover that series. Confused. No problem this is the manual for your model=> RB1855SL If you need more assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 16, 2010 | Samsung Refrigerators
Please send on my e-mail out the user instruction for Bosch WFL 187K washing mashine
I need a guide for Bosch WFL 187KTR/10. Thanks a lot in advance.
My e-mail is lelic-bolic@list.ru
Oct 19, 2009 | Bosch Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
I need a price and delivery for a manual for my Equator Clothes Processor EZ3600EE pfl200210335,4580047283. Thanks
Equator Advanced Appliances
2801 W Sam Houston Pkwy North Suite # 150
Main: (713) 464-3422 / (800) 935-1955
Fax: (713) 464-2151
Email: mail@equatorappliances.com
dottedline.gif CONTACTS dottedline.gif • Customer Service
(800) 935-1955
service@equatorappliances.com dottedline.gif dottedline.gif • Technical Support
(888) 935-1565
techsupport@equatorappliances.com
dottedline.gif • Parts
(800) 776-3538
parts@equatorappliances.com
Sep 29, 2008 | Equator Washing Machines
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
