Question about Vizio GV42L 42 in. LCD Television
How do I turn Off the RGB no signal screensaver on my VIZIO ? Everytime I get comfortable on the couch it goes blue screen on me and makes me get up to move the PC's mouse.
    President:
  • 1,623 Answers
The problem is on the pc my friend not the tv, right click on the desktop of the pc and click properties or screen resolution then click on screensaver .then change the turn monitor after 30 minutes or whatever its set to , to none. Then your tv wont show no signal as the pc wont be turning off the signal
Posted on Mar 30, 2011
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
I hit the "RGB" button
Look for a button named "AV", "AV in", "TV" or "Source" any or all of these should work.
Apr 04, 2011 | Vizio L32 32 in. LCD HDTV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
Aug 27, 2009 | Vizio VX42L 42 in. LCD TV
Stuck in RGB input.
i imagine your problem is over by now one way or another, but for anyone else experiencing this problem, thought i would share. your rgb input is tripped and needs to be reset, there are multiple things that "may" fix this, but the sure fire method is to connect a laptop to the rgb input, make sure you change your display settings on the laptop to "external monitor" and change the monitor selected in display settings on your computer. When the TV recieves a signal (which is what it is wating on and why it is frozen) it will then allow you to change input and will not turn off. Make sure your computer is running and all display settings are set before turning on tv so it does not time out and shut off before you can get it to pick up the signal
Jun 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
When i turn on y Vizio LCD TV theres a blue screen that says no
Your TV is probably in RGB mode which means its looking for a computer signal. Plug a computer into your TV and then it will stay on. Then you can change it back to TV mode.
Dec 24, 2008 | Vizio GV42L 42 in. LCD Television
42 in lcd vizio "no signal"
Had the same problem. My TV must have been puht onto RGB input. So I plugged my computer in to the RGB on back and turned on the TV. It stayed on. Then switch it back to input of choice
Apr 15, 2008 | Vizio VU37L 37 in. LCD TV
Vizio GV42L 42 in. LCD Television Logo
458 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
