Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
I have a Dyson DC-16 hand held - same problem as others reported; cutting out after 1-2 minutes. Called Dyson, and said it was the battery and replaced in free (that was OK!). Replaced the battery and it ran fine, but none of the lights came on (even when charge decreased). like wise no lights come on in the charger. Put the old battery back in and it still runs the vacuum, but also no lights now with this one. with this one. Finally, when back in the charging cradle, no lights and no charging. The power in the electric outlet is fine; it just appears not to be being picked yp by the vacuum and battery. Appreciate any help you can give.
ThinkVacuums
  • 144 Answers
SOURCE: Hi, this is our third Dyson DC-16.. the Trigger
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Posted on Oct 23, 2009
Testimonial: "Thank you for your solution, but we've had it at least a year.. it stays on charge when not in use.cleaned the connections.working better, not 100%.."
  • 389 Answers
SOURCE: The hand held dyson does not appear to charge.
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear. This can be quite hard work, and you may find a bit of additional leverage from a flat-blade screwdriver is helpful. It's a bit more difficult to answer your question about buying a new battery. The fact that the red light comes on would suggest that your charger is working, so the finger of suspicion does point to the battery, but without testing equipment it's impossible to be sure.
Posted on Jan 08, 2010
beltronic205
  • 1456 Answers
SOURCE: my dyson dc 16 hand held vacume stops & starts
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Posted on Apr 01, 2010
VacuumRepair
  • 438 Answers
SOURCE: Dyson animal is giving me fits
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    In terms of the machine not picking up, this could be caused by a few things.
    The first thing you should check is the filter. The DC14 has a motor filter that is recommended to be washed every 90 days. Here's how to access this filter:
    • To remove the washable filter: Remove the clear bin; and cyclone top from your machine by pressing the cyclone release button.
    • Lift clip to remove the filter from the machine.*
    *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
    There are two different types of filters that were used on the Dyson DC14, and One part filter, and a two part filter. Here's instructions on how to clean both of them:
    ONE PART FILTER:
    • Wash the filter in cold water only. (Please do not use detergent, do not wash in a dishwasher or washing machine).
    • Repeat the steps shown below until the water runs clear.
    • Leave to dry in a warm place for 24 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    • Please ensure the filter and filter case are completely dry before refitting into the machine.
    1_part_filter_drying.jpg TWO PART FILTER:
    • Wash the filter in cold water only. Please DO NOT use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
    • Leave the filter to dry in a warm place for 12 hours, until completely dry.
    • DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    The filter should be washed at least once every 6 months.
    Also, since you have removed the bottom plate, a common problem on the Dyson's is when this plate is reinstalled. It is very easy to put the plate on incorrectly, which prevents the brushes from hitting the carpeting. This can seriously decrease the pick up on carpets. Check the bottom plate to make sure that it was put back on properly. Here's pictures of both the correct, and incorrect way to reinstall the bottom plate:
    Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
    Here's another picture, that is the RIGHT way to install the soleplate:
    I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Posted on May 01, 2010
    promo7uk
    • 19 Answers
    SOURCE: My hand held Dyson vacuum will not charge. Every
    read my other posts on the faulty transistor pickup on here,,cheers lee.
    Posted on Jun 26, 2010
    How do fit dyson dc44 battery
    Hi there, it's Jack at Dyson.
    Depending on the age of your particular DC44, the battery will be held in place either by a round silver clip, or fixed in place by two screws.
    If you have the version with the clip, simply pressing this will allow
    the battery to be removed and replaced. The new battery will clip into place.
    If you have the version with the screws, you would need to undo these to remove the battery. One screw is above the charger connection on the handgrip, and the other is behind the washable pre-filter. To access the screw behind the pre-filter, please follow the steps to remove the filter shown in our filter washing video guide:
    If you'd like any further help or advice with this, you're welcome to get in touch with our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Feb 15, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
    How do i buy parts for my hand held dyson vacumn
    Call the Company on the box, or should be on Vacuum, where the serial/model numbers are located.
    Aug 27, 2014 | Dyson Dc-17 Hand Held Turbo Brush, Part...
    Short run cycle, cuts off
    Dyson cut out
    The motor is fitted with a thermostat. If the motor gets too hot the thermostat turns the motor off to avoid burn-out.
    When you normally vacuum you are using the machine in its normal upright position. When you clean your car you use the hose. When you cover the hose nozzel to sook stuff up it deprives the motor of air. Air helps keep it cool. (Its similar to puting your hand on the back of a hairdrier). Add to this the fact that any air it does get is a bit warmer than usual.
    Also a dirty filter will cause the motor to suffer lack of air so always wash your filter at least every 2 months.
    Jul 21, 2014 | Dyson Dc 16 Root Handheld Vacuum Cleaner
    Runs for a few seconds, then stops
    Hi Bente, it's Jack at Dyson.
    DC16 was the first Dyson handheld vacuum, launched back in 2006. It would have come with a 2-year guarantee, but due to its age it's likely that this has expired now.
    However, our experts would be happy to take you through some quick diagnostic checks when you have your machine to hand. This will help determine which part may be at fault - and therefore, what may need replacing to resolve the issue.
    If you would like some advice, you can reach our team of experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Mar 20, 2014 | Dyson Dc 16 Root Handheld Vacuum Cleaner
    Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
    If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
    Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
    Hi my dyson hand held dc 16 runs for 10 secs then for 3 secs until you let it rest, then it does the samething again
    take it apart and look for some trash might be rapped around the motor,because if the motor heats up it will shut down to keep it from burning up
    Mar 31, 2011 | Vacuums
    My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
    Apr 01, 2010 | Vacuums
    My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
    I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
    Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
    DC 17 Animal No suction on hand held hose
    There is likely a blockage in the pipe. Try pushing something through taking care not to perforate the pipe.
    Jun 21, 2009 | Dyson DC14 All floors Bagless Upright...
    Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
    59 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
