Question about Sony Playstation 3 (PS3) Console
When i turn on my PS3 there is no signal found.
    Novelist:
    Sniper:
  • 90 Answers
Hi guyghrist,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your graphics has overheated. You just need to stop the heat build up in order to make it work again.
Solution:
The first way you can fix the No Display Error is by sending it in but bear in mind for this problem there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
You can find them all here:
Click Here For A Closer Look At All The PS3 Repair Guides On Offer And How They Work
Posted on Apr 16, 2011
I just brought my PS3 i want it to connect to the wireless internet. so i went to network setteing, went through the to scan for wireless internet and it found the signal but when i follow through to is...
you need to sequential power cycle all the equipment, turn off ps3, turn off router, and turn off modem. then one by one turn it on. start with the modem. and wait for the lights to settle in. then the router. if all the lights had settled in. turn on your ps3 then try to connect again. this should work
Aug 31, 2011 | Computers & Internet
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
Scott tv LCT37SHA. The hdmi input doesnt work. It doesnt recognize the signal. Is this a common problem. I tried everything.
I have this same problem as well, While i have not found a true solution i have found a theory as to why. I have 3 hdmi devices to the 1 port. The Xbox 360 hooked up to it works fine, however the dish and the ps3 do not. When run though a switchbox however i can get the Dish to work by turning on the 360, this trigers the port on and after its on i can turn the 360 off. however this does not work for the ps3. My best guess is that the TV is not receiving enough power from the cable (or sensing) to triger it to display the signal. Its just a theroy though
May 26, 2011 | Akai LCT3201AD 32 in. LCD Television
Why doesnt my tv recieve signal from my ps3
Your tv might not receive a signal for a variety of reason.
a. You have the RCA (yellow,white,red) cables plugged in the wrong way
b. Your ps3 hasn't recognized your video due to using an hdmi cable and switching around with the settings on your ps3.
c. you have changed the video settings on your ps3 and is now set to the wrong video output.
d. the cables have become defective and you need to purchase a new one.
e. the ps3 has malfunctioned and wont take video anymore.
f. the tv input is set wrong. make sure all RCA cables are found in "video output", all hdmi cables are found in "HDMI", and all VGA cables are found under "PC".
Your guess on the problem is as good as mine.
I hope everything goes better for you : )
Dec 30, 2010 | Video Game Consoles & Games
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No signal on my TV
have you changed ps3 output to hdmi?
May 28, 2009 | Sony Playstation 3 (PS3) Console
Turning on PS3 causes home wireless network to stop working
I have the same problem. My router is located about 1.5 feets from the PS3 and when I turn on the console my wireless network barely works. Something I did was change the frequency of the wireless. It was working in channel 9 and now it's on channel 3 with no problem.
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Wifi controller for PS3, Does radio signal turn off when USB is plugeed in?
The Bluetooth radio signal will stay active as long as the controller is turned on, the USB cable doesn't switch the radio signal off.
Jul 28, 2008 | Sony PlayStation® 3 (60 GB) Console
Ps3 menu
have tried turning off the auto game start
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
How do I get my PS3 Online?
right fist of go on settings on the ps3 menu then go to network setting then click onsettings and connection status list take a note of all the ip addresses and servers then go to internet connection on the same menu and click on scan then click on your router name and then lick onenter ur wep key if u av 1m but if u dnt then cck on none then press right then go o custom on the address setting then manual on ip adress settings type in all ip address and servers and stuff then click on auto on the mtu dont use proxy server enable unpn click right then press x to save ur settings then test connection thn hopefully this works for u m8 cheers arsenal_07
Mar 24, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
