What funtion does the pink wire have on the honey well zone valve
  • 1,420 Answers
If you are referring to the two red wires, they are from an end switch that closes when to zone valve is wide open. You can use them to power a light so you know the zone is calling for heat or complete any other type of circuit.
Posted on Mar 30, 2011
Lyrics for pink cadilac
Pink Cadillac
Bruce Springsteen
You may think I'm foolish
For the foolish things I do
You may wonder how come I love you
When you get on my nerves like you do
Well baby you know you bug me
There ain't no secret 'bout that
Well come on over here and hug me
Baby I'll spill the facts
Well honey it ain't your money
'Cause baby I got plenty of that
I love you for your pink Cadillac
Crushed velvet seats
Riding in the back
Cruising down the street
Waving to the girls
Feeling out of sight
Spending all my money
On a Saturday night
Honey I just wonder what you do there in back
Of your pink Cadillac
Pink Cadillac
Well now way back in the Bible
Temptations always come along
There's always somebody tempting
Somebody into doing something they know is wrong
Well they tempt you, man, with silver
And they...
Jan 08, 2017 | Audio Players & Recorders
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
I have a Toro 240-06-04 which is almost identical to the 250. My sprinkler system on the number one valve quit working. I thought maybe it might be a solenoid, so I replaced that and it still didn't w
Connect the wire form a working zone to the valve to zone 1. If the zone comes on you have short in the wire for zone 1. You can confirm this by connecting it to the valve that was working and it probably will not. If you have a spare wire connect it to zone 1 and in pin 1 at
the timer.
If valve still does not open and you replaced the solenoid (which is rarely the problem) the hydraulics are probably worn out in the valve. Purchase the same valve and switch out everything accept the valve body itself essentially rebuilding the valve.
Bad wire, no spare and you want to avoid running a new stretch. Merge this zone with a similar one by connecting both valves to 1 wire. If the pressure is good they should all work as 1 zone. Otherwise you will have to run a new stretch.
Apr 21, 2014 | Toro 250-06-04 1 in. FPT Electric Valve...
How do you treat an infected eye using a home remedy?
Put orange juice and dishwishing liquid in it, it'll be fine after a two or three hours(!)
Serioulsy, I don't think you can treat an eye infection with home remedies. See a doctor, or at least, a really good denist. It's close enough(!)
Nov 23, 2010 | Health & Beauty
Newly installed white-rodgers zone valve works for a while then eventually moves to manual (or open) on its own. Suggestions on how to keep valve in a closed position? Chris in Alaska
This problem has to be in the way the valve was wired. Wrong zone valve-Normally open instead of normally closed-power interuption causing valve to open. Faulty T-stat/ Most likely wired incorrectly.
Sep 13, 2009 | Plumbing
How do i install a zone valve in my hot water heater. I need the schematic from boiler controller to the valve. if I tie the first floor to one valve , the rooms (2) will be on the last section before the...
The two zones have seperate supply and returns, correct? If not zoning will not be possible without piping the system in that way. Assuming the piping is correct, for two zones, you will need two zone valves, one cut into each zone. The wiring will vary, but for a 3 wire zone valve, (Taco), power from the transfomer goes through the thermostat, into terminal 1 on the Zone Valve, Terminal 2 on the zone valve goes back to the transformer, (24v common), and also to one "T" terminal on the aquastat (boiler control), and Terminal 3 on the zone valve goes to the other "T" terminal on the aquastat.
For a Honeywell, or other motorized Zone Valve, power again goes from the transformer, through the thermostat and into one side of the motor contacts/wires (depending on brand), the other motor wire goes back to the transformer, (24v common) Then the two end switch contact/wires go back to the T T terminals on the aquastat.
If you are using motorized zone valves, and only 2 of them, the transformer in the aquastat will be strong enough to power them.
Hope this helps
Jul 04, 2009 | Kenmore 75944 Gas Dryer
Eclipse AVN2210p tom tom continuously restarts
What Navcore (application) version and map version do you have?
Mar 20, 2009 | Eclipse AVN2210p MK II CD Receiver w/...
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
