Question about Dryers
The heat isn't working. A have cleaned everything properly (including heat exchanger) Is it maybe some reset function i can test?
From my experience could be the heater coilif theere is break in it won't heat
Posted on Apr 03, 2011
How do heat exchangers work?
The heat exchanger is a thin metallic component of a fossil-fueled furnace whose purpose is to transfer heat from the gas or oil buning on one side of the sealed chamber to the air passing across and coming in contact with the other side of the sealed chamber. By 'sealed' I mean the burning gasses do not come in contact with the air that circulates within the living space.
Mar 11, 2015 | Heating & Cooling
I have a Carrier model # 58MXA080-F-15112. I think my furnace is 30 plus years old. it isn't heating properly. The blower turns on and sometimes the flames come on, but sometimes they don't. As...
A 13 code means the furnace cycled on limit more than three times consecutively and is in a lockout for 3 hours. A 14 is ignition lockout. An ignitor does not intermittently quit working. I'm the service mgr at our shop, and I know that particular furnace model has a service bulletin out on bad secondary heat exchangers. If your lucky the filter is dirty, or the furnace condensate trap or drain is clogged. Most likely the secondary heat exchanger is plugged up and isn't allowing the pressure switch to make. Or the furnace is overheating due to it not being able to properly vent hot gas. Which would explain the high limit lockouts. Call an authorized carrier dealer so you can take advantage of the free heat exchangers and the $300 labor credit. You can also call an authorized Bryant dealer to perform the work for you. Only an authorized dealer can rectify this problem because the Bryant corp requires testing and paperwork in order to get your free parts and labor credit.
Good luck.
Dec 23, 2012 | Heating & Cooling
Canon NP6545 Error 0005, please help me... Tq B4
this is error for fixing web cleaning belt.call service for exchange of web.
BUT THIS IS OLD MODEL AND MAYBE THER ISN'T SPARE PARTS AVAILBLE ANYMORE.
THIS ERROR CAN BE RESETED IN SERVICE MODE, BUT IT IS COMPLICATED FOR YOU.(BECAUSE OF SERVICE TOOLS AND SKILLS )
Aug 20, 2011 | Canon NP 6545 Copier
I have a 2yr old Whirlpool Condensor dryer model no. AWA970B - 7KG. The dryer itself is going but it isn't drying the clothes. There is no heat coming out of the heat exchanger and the heat exchanger...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Whirlpool Dryers
Having problems with metal staining. i was told that i should clean the heat exchanger. can i just take off the front header & flush the tubes with some d-lime. Thanks
There is a very specific method for cleaning heat exchanger tubing and using any acidic cleaner could potentially cause damage to the tubing, especially if it is erroded. As to metal staining in your tub... cleaning the heat exchanger is NOT the answer! If the staining is copper, then cleaning the heat exchanger is NOT going to correct the problem!. Your heat exchanger is likely copper and if it is the source of the copper staining, then the problem is NOT the heater, the problem is your water chemistry. In most pool service calls I have done, involving staining from copper or iron, the most common problem was low pH. If your test is showing a pH of lower than 7.2, then add pH increaser (baking soda) based on a base demand test. If after adding the needed amount of pH increaser, the pH remains below 7.2, then perform a pool stabilizer (cyanuric acid) test. If the results show higher than 80ppm, drain at least 50% of the volume and refill and retest again. A high stabilizer level in excess of 100ppm will result in a low pH and cause metals like copper to dissolve and stain the pool. Get the level down to around 30-40ppm if possible. Stabilizer is added to chlorine tablets to help hold chlorine in the water longer. You can unstabilized chlorine, but chlorine consumption is higher as a result. If the staining is copper, you should dismantle and inspect your heater for erosion and possible early stage leaks. Replacing the heat exchanger can be very costly. Proper preventive maintenance and chemistry balance will keep the staining issue under control. There are some products available on the market to assist with balance, staining treatment and overall chemistry control. I suggest looking at products by EasyCare, called Pooltec, Scaletec and Beautec. These may be beneficial for your situation.
Aug 04, 2011 | Hayward H-series Electronic Gas Pool...
Lack of heat in interior with warm engine and properly functioning cooling system, can i bypass controlling coolant flow to heat exchanger?
Umm if you do not have heat then you don't hav a properly functioning cooling system..;)
Replace heater core..
Nov 25, 2010 | 1997 Ford Explorer AWD
No heat
check the vents ductwork It maybe clogged up full of lint causing the heating sensor to work properly. If clogged up and cleaned it will work again for you
May 01, 2010 | LG DLG5988 Stainless Steel Gas Dryer
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Microwave not heating
OK, if everything, including the fan, is working, this will confirm Magnetron failuer. you cannot reset the function of a failed Magnetron heating unit. replace this failed device asap if possible.
Jun 05, 2009 | GE Microwave Ovens
No heat
THE AIRDUCT EXCHANGE FUNCTION IS NOT WORKING , IT MAYBE THE CONTROL SWITCH ITSELF .WHAT TYPE OF VEHICLE IS IT
Aug 12, 2008 | 2005 Chevrolet Malibu
Dryers Logo
19 people viewed this question
Top Dryers Experts
