Question about Maytag Washing Machines
Spin cycle does not work washer it fine till then. checked belts belts r fine to.
    Brigadier General:
  • 6,277 Answers
(try this)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 30, 2011
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
Spin cycle does not remove excess water (worked great till recently)
EITHER A LOOSE WORN OR BROKEN BELT, A LOOSE SLIPPING CLUTCH A BAD DOOR SWITCH
Apr 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
