Question about Emerson MW8987B/W Microwave Oven
Stopped working I was using the microwave - it completed the cycle. I took the item out the shut the door and it has not worked since. everytime i open the mcirowave door it blows the circuit.
  • Emerson Master
  • 9,098 Answers
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
Posted on Aug 08, 2008
The oven door won't open. It happened when it wasn't being used. How do I get the door to open?
If it is a self cleaning oven try running it thru the clean cycle to see if the door will unlock at the end of the cycle.
Apr 24, 2017 | In Microwave Ovens
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Fan continuously runs, have to leave door open
Check the door switches with digital meter, usually find one bad one. Set meter to ohms and test, some will be normally open and others closed, check with the door open and closed.
Jun 20, 2012 | GE JVM1850 1000 Watts Microwave Oven
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
After a brief use, my microwave shut off, said end, and after we removed the item inside, the face of the oven went black. We have tried plugging and unplugging the oven into other outlets, but it still...
I say this a lot on here, but may be bad fuse due to bad connections. The fuse holders these companys use are so cheap they get hot if the unit is run for a long time and the fuse Melts at the end, and goes bad. Possibly something shorted out and blew the fuse, But, it had gotten to the point where it said end so it had completed the cook cycle. So, either over heated fuse, or bad door switch that caused it to blow the fuse.. If another switch goes bad or doesnt act like it should, another one is designed to blow the fuse when the foor is opened as a protection feature.
Oct 06, 2017 | Whirlpool MH1140XM Microwave Oven
LMV1630st sparked and then stopped working.
http://www.fixya.com/support/t886241-power_turns_off
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
Sep 01, 2008 | LG LMV1630ST Microwave Oven
Stopped working
check door switches, and control circuit and related spaes.
Oct 28, 2007 | Emerson MW8107WA Microwave Oven
Microwave Fan Running for 24 hours
Sounds like cycling the power line did it.
Emerson MW8987B/W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
