Question about Pride Sonic 3 Wheel Portable Scooter
My sonic disability scooter's battery is fully charged but speed has dropped dramatically Has anyone any solutions please?
  • 3,866 Answers
Most of the scooters expeinece a bad control board, this control board is where you steer and power on your chair. This is a costly repair and would need certification because its a mobility device. I recommend you have it repaired locally instead of taking advice on the web as the issue could be something simple, because I worked on my dad's device I thought I would give you a hint of what it could be.
I would appreciate if you leave positive feedback before you leave please.
Posted on Sep 26, 2011
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
I charge the battery and mark it's full charge,but on the scooter the indicator don't mark is full charge and when you drive,the speed just suddenly will drop and come back ok.
Charging batteries to full means leave on charge for 12 -16 hours as it may show charged but the charger goes into what is called a battery conditioning mode where a small trickle charge takes place to fully charge batteries. Again, how old are batteries and have you had them load tested at all?
Jun 15, 2015 | Drive Medical Health & Beauty
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Not charging flat batteries
hi, most mobility scooter charges will not attempt to charge below 10 volts,
the trick is to use a car battery charger to bring the voltage past 10 volts then you use the mobility scooter charger to fully charge.
However please be aware of a couple of points:
1. Car chargers will damage mobility scooter batteries.
2. Once a Gel or AGM battery voltage has dropped below 10 volts they may never fully hold the charge again if they do recover and that's a big if.
Regards
Robin
GeWiz.
Feb 18, 2013 | Health & Beauty
I have an Invamed delux 4 wheel, its basically a SPRINTER XL4. it has done about 4 miles.i have fully charged it,according to the charge indicator all lights are fully red meaning it is fully charged...
Hi im disabled myself.Please get the batteries tested properly.fully charge them for time given & take to battery centre or ring them & ask if they can drop test them for you,hope i was of help,Colin.P.S.Visit:Shoprider.com & see what you can download as a PDF File,print n save for future.
Aug 01, 2010 | Health & Beauty
Pride sonic scooter won't turn on. the battery is charged and the motor is functional. Appears to be an electrical switch. any suggestions?
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Jul 08, 2009 | Pride Sonic 3 Wheel Portable Scooter
Battery fully charged, buzzing sound when i try to ride scooter, but scooter will not move
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
Jun 11, 2009 | Pride Sonic 3 Wheel Portable Scooter
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Pride Sonic 3 Wheel Portable Scooter  Logo
141 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
