Question about Garden
Where could i get spare parts high pressure o rings for the pistons on Karcher 620mh
    Problem Solver:
  • 7 Answers
Try this place. They seem to have more than just the bits on offer from Karcher own site.
http://www.sparesgiant.com/p-67142-karcher-k650-m-plus-pressure-washer-11384050.aspx
Posted on Mar 31, 2011
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Loss of ppressure because of leak from motor
Dear Danny,
For sure the leak has to be fixed. Most probably the O rings that prevent the oil coming out or going into the head are damaged. You can open the cover first using a Torx T15 screw driver. The head can be removed by using Alen Keys in many cases. If you find the compartment of the oil under the pump head full of water the seals are damaged.
Now before one changes the seals, the pistons mustbe checked. If the pistons ( 3 in number have scrathes or grooves it is useless changing the oil seals. In that case the pistons must be changed.
If the pistons are found in perfect condition..( which oftenly are not)...then oil seals can be changed....and also all gaskets. This job is better done by a qualkified technician......but if you have the tools and a bit of mechanical back-ground...it is child;s play. Always when working see that electricity is not connected. I wish to add that the high and low pressure seals must be damaged also. Thus the pressure drops. Also sometimes instead of oil they are using a type of grease. You can see it as it resembles butter. As I said if you have the tools and all spares available....go ahead and good luck!!
Regards,
Fulltech.
Apr 10, 2011 | Karcher K2.26 Electric Power Washer
My winner 11, has developed a bad leak and has lost pressure, i assume I need a set of O rings, where can i purchase spare parts, i live in Adelaide
If there is no Karcher agent near you, most hardware shops and bearing outlets keep a range of o rings in stock. Take samples ot the part with you to get the correct size and thickness of o ring for your needs. Remember to put a bit of lubricant on the o ring when installing it.
Apr 07, 2011 | Karcher K2.26 Electric Power Washer
Gas mixing with oil even while motor is running. whats causing this?
if its smoking alot oil ring on piston stuck in oil passing the piston engine will smoke
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher K3.48M electric pressure washer which used to shut off when you weren't using the cleaning wand. This no longer happens and there is alot of water running out of the bottom of the unit....
hi you will have a 8 digit number on a silver plate on the machine with a number like 1.141-470.0
Then go to www.karcher.com then on the left click on Europe, then you will see International,on the left again you will see service click on that, then click on spare parts. you will see a box to enter the model or better still the 8 digit number. then tick on, i am aware parts should be fited by a trained enginner,always choose the largest pdf file, parts always same number in all countrys. hope that will help.
parts for karcher @ Q Services 07970636222 ring
Oct 18, 2009 | Karcher PSI Electric Pressure Washer
Why is my karcher jet wash smoking excessively?
could be bad piston rings, or if its a 2 stroke engine (probably not) then you could have too much oil in the oil/gas mixture. maybe even too much oil in the crankcase.
Oct 07, 2009 | Karcher 2500 PSI Pressure Washer
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
