Question about Samsung HCN653W 65" Rear Projection Television
Bow at top and bottom of screen
Has good picture in the middle Good picture in middle, bows inward top and bottom.
  • 13 more comments
  • Juan Campbell Aug 06, 2008
    WHAT CAN BE DONE TO FIX THE PROBLEM?
  • Juan Campbell Aug 11, 2008
    High Def channels do not come at all
    Does anyone know the part number for a convergence board for My Samsung 65 in rear projection T.V?
  • Juan Campbell Aug 13, 2008
    I bought a new board that states "Does not have STK's" what are "STK's" ?
    The perfect focus will not complete it's cycle.
    What is the auto focus module and where can i get one?
    Can I buy a convergence module with STK's on already on it?
  • Juan Campbell Aug 25, 2008
    I need to find a place where i can purchace the board and ic's because the replacement part does not have stk's and i don't know where to put them on.
    does anyone know where i can order the board with the ic's already on it?
    Or if they can also put them on I would be more than happy to pay them for their time and effort.
  • Juan Campbell Aug 26, 2008
    I don't want to pay 700 dollars for a 65 dollar part I can put in myself. There has to be somone that will put the IC's on the board for a reasonable price and send it to me.
    Votit, I replaced the part pictured on your reply.Still the same picture.
  • Juan Campbell Aug 30, 2008
    I replaced 2 boards so far from Partstore.com. Item # BP9500415B & BP950014P. Still same problem. I can not change the conergence and and when I push the perfect focus button it says "check factory data " in the upper left hand corner.
    The "check factory data" in the upper left corner is something new.
    Master:
  • 638 Answers
Take it to the service center.last option.thats it.
Posted on Aug 30, 2008
  • 157 Answers
Try this linky
http://www.partstore.com/CompatibleModels/Samsung/Samsung/BP9500142P/New.aspx
Otherwise, id recommend you get a tech to fix it if you dont have the tools necessary to fix it
Cheers
Posted on Aug 26, 2008
  • 2,071 Answers
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Hope this may help;
Regards,
VOTIT
    Genius:
  • 1,226 Answers
That only a matter of adjustment, however you need a expert repairman to do the task.
please call the service center or the repairman near your location.
melnavz
  • 83 Answers
Hi check the avaiability and compatibility here,
http://www.samsungparts.com/search/search.asp
Posted on Aug 25, 2008
  • 4,234 Answers
Back to the original problem... As stated elsewhere, the problem is with the convergence circuit. This is the circuit that aligns each of the 3 colored tube outputs to create the picture. The "STKs" referred to here are large black ICs attached toa heatsink. If you open up the back, you should be able to see the heatsink and the ICs attached to it. These are called STKs because the part number starts with STK. FOr example a common one is STK392-110. This may or may not be the one in your set. If you are not sure, post the markings on the parts here and I'll confirm that you have the correct part. Along with the STKs, there either a couple of fuses or low valued resistors in close proximity to the STKs that often go bad as well. If you can solder, you should be able to repair this yourself. Try resoldering the pins on the STKs first. Often poor solder connections can cause the symptoms you see. If the resoldering fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Posted on Aug 24, 2008
  • 1 more comment
  • ABRsvcs Aug 25, 2008
    What you are requesting is In-Home service that can be provided by any servicer in your local area. There will be a cost for this, probably in the $300 range for labor plus parts. WIth the problems as you have described, expect a totatl bill up to $700 depending upon whether the board is repaired or replaced.
    Help this helps,
    Dan
  • ABRsvcs Aug 27, 2008
    Thanks for the update. With the entire module being replaced with no effect on the symptoms, leads us to the power supply section of the set. There should be a low voltage supply for hte convergence circuit. This is usually a 24V supply. This is usually either fuse protected or protected with a low valued resistor used as a current limiter. In either case, this is the next area to investigate. The power leads should be marked at the connector. Measure the voltages at that point to see if they are corect. If not, check the power board for resistors or fuses that feed these connectors.
    Keep us posted.
    Dan
  • ABRsvcs Aug 30, 2008
    The factory data that is missing should still be present on the old board. Since the new one had no effect, I'd restore the old one and look for missing voltages to that board. If the original board is indeed bad and you need the new one, then a complete convergence procedure must be done. This will require a signal generator and should be done by a service tech as there is a particular sequence for proper convergence.
    Dan
  • 4,472 Answers
If you are trying to fix it yourself as previously mentioned you need to buy the convergence board. If you are not confident in your ability I can assist you in locating the nearest service center. If you need any other assistance please let me know. If you found any one person's solution helpful I hope you will accept and rate the solution accordingly.
Thanks,
Lee
    Genius:
  • 1,665 Answers
Convergence problems are usually caused by a diode on the convergence board.
Obviously, this is not a job for the home owner because experiece on electronics repairs is needed. So, call in the technician to make the troubleshooting of the circuit.
Posted on Aug 18, 2008
    Scholar:
  • 163 Answers
See a convergence board is available at link
    Sergeant:
    Champion:
  • 417 Answers
Turn of power for 30 mins make sure no speakers are close to the tv or any magnetic items then turn back on after 30 mins
Posted on Aug 16, 2008
  • 69 Answers
This has to do with the amount of light allowed through the transistors. If warranty is still in effect, have it replaced. Make sure you check the settings to make sure that they arent set for widescreen. The HD channels not coming in is the STK IC resistors/transistors. Hope this helps!
Posted on Aug 14, 2008
  • Samsung Master
  • 8,617 Answers
The part number you need is BP95-00142P which is the convergence amp board comes with ICs already installed. Here is where you can get the new replacement board for the P55A chassis which is what you HCN653W is. Heres the link.
    Master:
  • 521 Answers
STK is an ---ic--- on the convergence board
if it says that it does not have STK means the board comes without any STK IC on it.
Posted on Aug 13, 2008
  • tech expert12 Aug 14, 2008
    yes you need to buy the board with stk ic on it. re rate the solution if the information helps you.
  • tech expert12 Aug 25, 2008
    call the mechanic who repairs the projection tv .he will himself get the board and fit it for you.also provide you with a six months garantee.it will be fine .do not worry.thanks.please rate the solution sir.
  • 2,296 Answers
Check this link to have an idea how the part looks like. The STK ICs are the ones you see on the picture.
Do a search with the exact model number on the site.
  • Jaime Hernandez Aug 14, 2008
    I just gave you a link where to buy the entire board with the STks already in the board.
    Genius:
  • 1,011 Answers
Dear,
it seems the convergance problem as mentioned here . you have to buy the unit.
regards,
Posted on Aug 12, 2008
  • 3 more comments
  • SALMAN NASEER Aug 14, 2008
    dear,
    STK is basically a voltage regulator that is used in the circuitry of the convergance board.
    you have to buy it and try with a fine method in the circuitry..
    hope the problem will be resolved..
    regards,
    dear,
    try to repair it if you already has the knowledge of it..
    if not then fix it by an expert tv technician.
    more heat of solder can cause damage of it.
    so becareful about it..
    regards,
  • SALMAN NASEER Aug 15, 2008
    dear,
    Becareful about the exact STK for this board. otherwise u have to face problems.
    regards,
  • SALMAN NASEER Aug 16, 2008
    dear,
    did u find the STK and tried for that or still in confusion...
    regards,
  • SALMAN NASEER Aug 24, 2008
    did u find anything in positive
    Scholar:
  • 65 Answers
Just a long shot. their may be a setting to change in the options manual. however if it isn't then it would be an internal problem. such as the screen or the projection modual.
  • 1,029 Answers
If it has auto focus and can not complete its cycle. then the
Auto focus module is bad,
If it completes and the problem is still remain s then convergence is the problem check for bad conv. drivers or cold solder joint on one or more of the 3 drivers pins.
Posted on Aug 11, 2008
  • Starnley Johnwells
    Starnley Johnwells Aug 14, 2008
    some samsung models does not have stk on the convergence board it depends on the model .check the link http://servicemanuals.vstore.ca/ i will recommend replacing the IC's as well as checking also the IC resistors . just the convergence board with the STK ICs.
    check the traces from the connectors to the STK IC before replacement
    You may find replacement parts elsewhere for slightly cheaper but not reliable you have a provision of calling them should you have any questions before or during repair. plz dont forget to accept my soln
    Master:
  • 623 Answers
Http://org.downloadcenter.samsung.com/...df
go to this site
  • 3,037 Answers
A new convergence board will fix the problem. They are not cheap but you can purchase one from the manufacturer or cheaper from an online store. Let me know of anything else you may have questions or need help with
my best to you
Posted on Aug 06, 2008
  • Benjamin Patri
    Benjamin Patri Aug 13, 2008
    STKs are a couple of chips that you can buy from any electronics store like Radio Shack that have to be soldered onto the board. Without them, basically, no picture. They are fairly cheap but you need to know how to solder, Radio Shack can do it for you.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
This is the clear problem of convergence. Replace the convergence board it will be OK.
Y ordered from this site http://www.vancebaldwin.com/ at less than total $83including UPS ground shipping. After I instlled new convergence boardand connected 5 cables, two from board to TV and 3 from TV to board, TVwill be worked fine. It is easy to replace and u did not need technical mannual toinstall new convergence board.
Thanks
good luck
    Sergeant:
    Champion:
  • 236 Answers
If its still in warranty, have a service person come look at it.
Online Request
or phone 1-800-726-7864
If its not in warranty, you could try to align the mirrors inside and risk breaking the whole tv or have someone give you an estimate and then decide on paying for service or a replacement.
  • Samsung Master
  • 19,396 Answers
It is probably a problem with the mirrors of the light tunnel.
Posted on Aug 04, 2008
  • 7 more comments
  • Ginko
    Ginko Aug 24, 2008
    Hey libra, do not exaggerate with technical definitions, STK are ICs and are power amps, not voltage regulators, just find this guy a replacement convergence board or send him to a technician.
    Troubleshooting electronics is a serious matter.
  • Ginko
    Ginko Aug 24, 2008
    To the user I would suggest to call a technician, if you want to DIY buy the convergence board posted by slinterior here: partstore
    Eventually reward slinterior for posting the part.
  • Ginko
    Ginko Aug 25, 2008
    lol
  • Ginko
    Ginko Aug 25, 2008
    partstore has the replacement, you need to insert TV model number. Before refusing all our solution let us know if you have any other query.
    Many thanks
  • Ginko
    Ginko Aug 26, 2008
    Is simple, replace the whole convergence module here for $89 :Convergence module
    Or replace convergence board without STKs for only $66 and mount your own ICs.
    Samsung BP95-00415B Convergence Module Board (Does Not Have STK's)
    Parts are for your TV model.
    Possibly vote the solution.
    Thanks
  • Ginko
    Ginko Aug 26, 2008
    Did you replace the whole board?
  • Ginko
    Ginko Aug 27, 2008
    I told you you can buy board with ICs on it for about $90, the board is easy to fit, link is above.
  • Ginko
    Ginko Aug 30, 2008
    If you get "Check Fctory data" you need to access to service menu and re calibrate the convergence, it is not same as perfect focus, perfet focus is just preset convergence alignments the other is a service procedure.
    Here is how to access to service menu
    On some models:
    Put tv ond standby, try MUTE-1-8-3 hidden menu sequence on remote.
    or
    TV has to be in Standby mode
    Press INFO
    Press MENU
    Press MUTE
    Press POWER
    Then you must find convergence calibration, you need service manual to proceed.
    the whole procedure is listed on service manual.
    You can buy the service manual here
  • Ginko
    Ginko Aug 30, 2008
    "check factory data" means you did not do Service Convergence calibrate procedure, looks like I talk to the wind here.
    Look, if I post a comment it means I know it is true, if you keep refusing all comments without following anybody you only get a list of general comments, many of them may be just inaccurate information.
    When you replace the convergence ICs or the convergence board, you need to perform a convergence calibration procedure.
    To do the procedure you need the service manual and the remote.
    I do not have service manual for your model, I know only how to enter on service mode.
    Magic Focus it is not Convergence Calibration. Magic focus only set back convergence to a default value, Convergence calibration, among other settings, set the right value for auto focus after a new convergence board is installed.
    Refuse this if you want, but this is what you need to do. Period.
I have a JVC 48' widescreen tv approx. 7 - 8 yrs old. the picture is now extremely bad all of the colors seem to be out of wack and the picture bows inward toward the middle at the top and bows inward...
There's a miror or one like this might have a ''aluminium sheet'' miror.
Open the upper back cover to see what going on there, pretty sure something run out of place...
Sep 08, 2009 | Televison & Video
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 61SDX01B picture...
Sounds like the blue convergence circuit still not working.
Assuming both IC's are good, look for open soldered-in pico fuse.
Once bowing problem is solved,then convergence should adjust ok.
Jul 27, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
212 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
