Question about Konica Minolta MC1650EN Laser Printer
Idle M toner incorrect - Konica Minolta MC1650EN Laser Printer
Error is non genuine toner
Use genuine toner when refill. If it was refilled by a service, they use incorrect tones.
If message is incorrect and the toner is the correct, your printer has come electronic problem and should be repaired.
Jul 01, 2015 | Office Equipment & Supplies
Panasonis u13 code
Add Toner 1. Toner Bottle is incorrectly installed.
2. Low Toner.
3. Toner Sensor is disconnected.
4. Toner Sensor is defective.
5. SPC PCB connector is disconnected.
6. SPC PCB is defective.
Mar 17, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Incorrect toner
defective toner... take it back to your vendor
Feb 28, 2014 | Lanier Office Equipment & Supplies
My Lexmark x2670 says left ink cartridge incorrect so I got a new one and it still says incorrect...help
Check and make sure it is an OEM toner. If you are using a 3rd party toner you will have to try the OEM.
Aug 28, 2013 | Lexmark Office Equipment & Supplies
How can i solve error code f2-04 in sharp 5127
The main reason for the error code is an incorrect toner cartridge being used in the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off 2. Remove the incorrect toner cartridge 2. Unplug the power cable from the wall outlet. 4. Plug the Printer back on 5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
If this resolves the problem good else you will have to replce the carrtridge.
Sep 11, 2011 | Canon imageRUNNER 8500 Copier
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
The toner is spewing all over the pages as it prints
Sounds like its been dropped / incorrect toner cartridge / inserted incorrectly, Major component failure inside the unit.
Oct 19, 2010 | HP LaserJet 4si Printer
Inncorrect tc type
incorrect type of toner cartridge was installed. only use the toner cartridge that has been manufactured specifcally for this machine.
Oct 09, 2009 | Konica Minolta Di1610 Copier
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Konica Minolta MC1650EN Laser Printer Logo
119 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
