Question about Sanyo Xacti VPCX1200 Digital Camera
The lense won't open, it comes up saying system error and switches off.
    President:
  • 287 Answers
Hello and welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
I hope this solution will helpful for you, Anymore help, I am here to help
If It is HELPFUL then your token of appreciation as Four Thumbs which are given below to this solution will be esteemed.
Thanks & Keep Visiting FixYa
Posted on Mar 30, 2011
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
The problem is when i switch my camera on, on the
ok so I was searching for the answer for this myself.. very hard to say, because it really depends on what happened to your camera.. Did you drop it? Did it emerge in water? But for me, I have come to the conclusion for everyone who has the problem.. it is most (99%) probably a problem with the lense.. another site told me to take it to get fiixed- or to take the battery out and wait 20 min to put it back in, because this resets it. I decided to manually open the lense myself (who knows if thats bad/good to do, but a girl's gotta take her pix!!) So anyway, i opened the lense, and turned it on- the "on again off again" msg went away. So most likely, the problem does stem to the lense not being able to be opened, so the msg pops up, if you open the lense yourself your camera works fine, when you turn it off- my closes the lense-just doesnt open it. different results for different people, but i hope this helps because it was very simple.
Feb 04, 2010 | Samsung NV4 Digital Camera
Printer says " Scannerfehler...Strom aus...Strom ein"
This error happens as the scan lamp ages and dust and debris settle on the mirrors and lenses. You need to remove the glass and clean the lamp surface and lenses, sadly if this doesn't help, new parts are hard to come by and are as pricey as a new machine.
Jun 23, 2009 | HP LaserJet 3330 All-In-One Printer
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Failure to detect dvd/cd. 'no disc' appears. Radio+ aux still ok.
You are having the issue with the tray with the lense problem thats why you are getting the " NO DISK" error, so you need to replace the entire kit that is tray with motor lense.
Apr 11, 2009 | JVC TH-A25 System
System error
turn on and off 6 or 7 times while banging on the body beside the lens, worked for me, apparently coolpix lenses tend to stick, as my girlfriend says " a good bang will solve many problems"
Dec 06, 2006 | Nikon Coolpix SQ Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Sanyo Xacti VPCX1200 Digital Camera Logo
129 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
