Question about HEWLETT-PACKARD Hewlett Packard HP PAVILION DV6-3130US ENTERTAINMENT NB PC - XG870UAABA PC Notebook
My laptop keeps overheating. The fan is constantly running and the left side of the laptop gets so hot it burns my leg when i am on it. how do i keep it from doing that? is there a problem with my laptop? should i send it back and get a new one?
    Brigadier General:
  • 8,909 Answers
I would check to see where the air inlet vent is, as sometimes that is why your leg is getting very hot.
There are numerous laptop guards for sale on ebay. That will keep the heat off your leg and encourage a better air flow.
Posted on Mar 30, 2011
I own a pulsar 150 UG4 2010 model since april 2010. Since then i notice that my bike gets over heated even in short trips say less than 15-20kms at a constant speed of 60-65km/hr. and burning smell comes...
check your spark plug and see what color it is, it sounds like you might be running really lean and that will cause the bike to run hot. if the plug is white or lighter in color thats most likely what is happing.
May 23, 2011 | Bajaj FLHTCUSE Screamin Eagle Ultra...
Tip
How to Prevent Laptop Overheating
There are some laptops that get hotter than other laptops. Laptops get hot due to many factors such as capacity of the processor, cooling fans,ventilation, extra items such as modem, video cards. They all produce heat due to which laptop gets hot.
You'll find many examples on the Internet for the laptops which get hot. There are particular laptop models which produce excessive heat. For example, IMB T60,Apple Mac Book Aeros, Compaq 610, Dell D400 etc.
But you don't need to worry now because there are certain methods by which you can stop overheating of your laptop. These methods are discussed below.
Place your laptop on a cool flat surface while working. It will allow the air to enter your laptop. Some laptops have cooling fan underneath and blocking this will make your laptop hot quickly.
Buy a laptop stand from a laptop seller. It lifts your laptop few inches from surface of the table making a reasonable space for air to enter your laptop freely.
Dust your laptop regularly; it will keep your laptop's fan functioning properly for a long period. The fan needs to do an extra work when there is dust inside the laptop. If you dust regularly, the fan will not experience any difficulty.
Shut down your laptop before putting it in the bag. The atmosphere inside the bag may be too hot for your laptop, and it can damage your laptop.
When the battery is full, unplug the charger. People make a common mistake leaving the laptop plugged in. Due to the constant supply of electricity to the laptop will heat its battery as a result it will overheat your laptop.
You can find certain kinds of items in many electronic stores for keeping your laptop cool. Cooling pad is a most common equipment to keep your laptop cool that sits beneath your laptop and is powered on with the help of USB port. It increases the airflow inside the laptop. So, cooling pad is the best you can take to keep your laptop cool and maximize its performance.
Give your laptop a little break if it is getting hot. It can shut down itself to protect any kind of damage due to overheating. This is an indication that your laptop needs a little break.
Do not expose your laptop to the sunlight for a long span of time.
on Dec 18, 2010 | Computers & Internet
Pavillion dv7 1132nr runs very very hot all the time to the point it burns my hands. I have a large laptop fan cooler under it running all the time. It is also very noisy as the fan on the laptop is...
I suggest try to call the manufacturer because if happens that its causing plastic burnt or dent due to overheating that means the hardware of the machine is failing, also the automatic shutdown is caused by overheating. If your going to call the manufacturer they have special support for those kind of issue.
Feb 12, 2011 | HP Pavilion dv7-1132nr Notebook PC
My Eee netbook just shuts off, the fan keeps running untill i get the black screen which can mean its overheating because the fan is constantly running. Please help me fix this problem ive spent way too...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 20, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Overheating
are you leaving it sitting on a fabric surface i.e- pillows. blankets... beds carpet?
also not enough ram, too much going on at one time can do that. Make sure your fan is working properly and maybe download a cpu temperature monitor. google it u should find something
Oct 06, 2009 | Dell Inspiron 1420 Notebook
New HP Compaq 6735s PC Notebook overheating
I suggest you get it checked out by the supplier undr warranty. Do not try to fix anything yourself because it most likely void your warranty.
Aug 07, 2009 | HP Compaq 6735s Notebook
Acer Extensa 4220 Overheating
if you burn a lot of cd or DVD this to will cause it to over heat, it should have feet on the back of the laptop and raise the rear ones to give it more air circulation also buy a laptop table fan that will plug into a USB port to keep the fan cool, with today’s processors and thin notebooks it's hard to keep them cool when doing hard work on them
Jun 21, 2009 | Acer 4220-2346 Notebook
Toshiba Satellite harmon/kardon overheating touchpad
Laptops to get hot, but not so they actually burn your fingers.
You say the fan is working and clean, ok , but when it kicks in does it stay on an excessive amount
of time especially under heavy cpu usage?
My first thought is you need the heatsink and arctic silver checked out on cpu, i could be wrong but it
sounds like your getting to the stage of overheating problems, and with prolonged use the laptop
will eventually at around 90C start cutting out.
Mar 31, 2009 | Toshiba Satellite P105-S921 Notebook
Compaq presario v2000 overheating issues...
Yes, this is a fairly common problem with the v200o, caused by a lack of good fan airflow. Your best bet in using it would be to get a laptop pad. This will not only keep your laptop cooler, it will prevent your legs from blocking the fans when it is on your lap.
May 08, 2008 | Compaq Presario Notebook
HEWLETT-PACKARD Hewlett Packard HP PAVILION DV6-3130US ENTERTAINMENT NB PC - XG870UAABA PC Notebook Logo
288 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
