Question about Garden
We need to locate the fuel filter on our Toro Gas Lawn Mower
  • Kiltnar Mar 31, 2011
    What engine is on this unit? Could you include the model number? Thank you this will help to make sure you have the best advice.
  • 46 Answers
Usually there is not fuel filter.
Posted on Sep 26, 2011
Toro lawn mower has gas pouring out of air filter
pinch of the fuel line with some pliers if it stops runing ot then you may have a float sticking or a bad needle & seat
Sep 10, 2012 | Toro Power Lawn Mower
Toro leaking gas through air filter
The inlet needle in the carb is leaking, it may be the activating arm has stuck, remove the float bowl and gently work the float up and down a few times, make sure the needle is moving. Failing that replace the needle valve.
Apr 13, 2012 | Toro Power Lawn Mower
When engaging the deck mower the motor slows, rather than regaining RPMs as the throttle is increased to max (Rabbit). The mower actually slows even more in thicker grass and occasionally stalls. ...
have you removed the sediment bowl located on the bottom of the carburetor and looked to see if there is a lot of dirt and gunk in the bowl,then while this bowl is off there will be a float (metal or plastic) make sure theres a good supply of gas running out of here where the bowl would normally be,if not,then it could be a plugged needle seat or port in your carb and will need to be cleaned
Apr 14, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Non-starting Toro lawn mower
If the mower was lying up for a time you will need to remove and clean out the carburettor and fill with fresh fuel.Stephen.
Nov 09, 2009 | Garden
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
Mower starts and stops with in a few seconds
Ok your not getting fuel into the carburetor it sounds. This could be either your carb.needs cleaned or your low idle screw on the carb. needs adjusted. The idle screw is located directly underneath the air filter. Remove filter and turn clockwise all the way and then counter-clockwise 2 1/4 turns, then test. Adjust until it sounds about right.
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
John deere js60 lawnmower is fouling the spark plug in 20 minutes. gas is good other mower works fine with same gas. can not locate fuel filter if it has one. large deposit of smut on plug.
sounds like your carb. is running rich for some reason
be sure to check to be sure your choke is fully off when running
follow your fuel lines they may have stuck the filter somewhere or they may be only using a tank screen filter.
Be sure you have the proper plug installed and gapped .030
most common plugs that are used the most is J19LM or RC12 YC
couple things to check for you mowers issue
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jim
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
