Question about Emerson Heating & Cooling
Furnace cycles too frequently. Installed new wall thermostat,didn't stop problem. Furnace is installed horizontal in rafter space.
  • 1,420 Answers
Systems are designed for a maximum of 6 cycles per hour. If you are experiencing more than that, you have leakage in your duct work or poor insulation or the system is too small for the area you are trying to heat. Some newer thermostats have an adjustment on them to allow you to set how many cycles per hour you want. Look in the instruction manual and adjust the DIP switches to your preference.
Posted on Mar 30, 2011
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
Furnace shuts down before heat temp meets thermostat. Furnace unit starts frequently. Service installed new limit switch and a new circuit board but furnace unit continues to malfunction. Same problems...
has any one checked your thermostat. as soon as the furnace shuts down then turn up the stat and see if it starts right up. i would think the stat function should have been checked also.
Feb 12, 2011 | Heating & Cooling
I'm not sure of the exact model of my Goodman furnace, but here is the problem. The new furnace was installed this summer (2010) and it is mounted in the space under the house in Big Bear Lake, CA....
I suppose this furnace is fueled by Natural Gas?
(Or is it Propane-- Bottled gas?)
Did the Service company leave you any manual, with your new furnace?
and I would think there was a warranty, for assuring you (the customer) satisfaction, no?
Have you called the people who sold/installed it?
What do they say?
If they did leave a manual-- what does it suggest for narrowing down your possible problems?
Like: Low Fuel-- Low Voltage- Filter Changes, Fan switch problems- or ignition failure problems?
For a new furnace, someone should be right there to do a start-up for you!
Let me know what you learn--
Mack B
Jan 14, 2011 | Goodman GMS80903BNA Heater
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
My 23 year old Rheem furnace stopped working not long after installing a programmable thermostat. Is the thermostat the problem or the unit is just too old?
If you did not turn off the power to the furnace when you installed the new thermostat. There is a very good chance that you shorted the thermostat wires and burned up the transformer in the furnace. Or, if you're lucky, you may have just blown the control voltage fuse if there is one installed.
Oct 29, 2009 | Heating & Cooling
Frequent cycle times on my home furnace
There are a few things that can cause this problem. The most common is the hole behind the thermostat for the wiring was not covered up when the thermostat was installed. The thermostat will sense the air in the wall space or the basement if it is open to the back of the wall supporting the thermostat. Turn off the power to the air conditioner if attached and the furnace, remove the thermostat from the wall and seal up the wiring hole with duct tape. Insure the thermostat is mounted level when reinstalled. The thermostat should be mounted to sense the return air to the furnace, if the stair well leads upstairs, warm air rises, so keep the upstairs close to the same temperature as down stairs or move the thermostat and install a door to block air movement to the upstairs. There is a heat anticipator on the thermostat, the setting for it is in the installation manuel. For most gas furnaces it is .8. It is very easy to short out the thermostat when making this adjustment, so always have the power off.
Nov 26, 2008 | Honeywell Electronic Programmable...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
99 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
