The power supply for my Linksys router was damaged. The cord was damaged and I am replacing the plug inserts into the router. Ine side of the cord has a gray stripe. Is this the negative connection?
    Scholar:
  • 79 Answers
In electricity ussually the cord with a different color stripe is positive, and plain black is negative or ground, I recommend you check out another power supply or go to linksys official website to get a new one. Hope you solve your problem soon.
Posted on Mar 30, 2011
What to do when the power is not stable
I'm not sure if you mean (1) your utility power supply is not stable or (2) your router power supply is not stable.
If (1) you can purchase an uninterruptible power supply (UPS). A line interactive unit will probably best.
If (2) the problem may be a loose or damaged power cord. Try jiggling the power cord at various points. Breaks usually occur near plugs but can occur anywhere, especially if you have biting animals around. Sometimes power plug pins can be bent slightly to improve connections. Make sure the power cord is unplugged before trying this!
Aug 13, 2016 | Computers & Internet
Wrt54gx2 won't stay powered up
Has the AC jack been damaged in the Linksys, due to pulling of the cord? Try wiggling the plug at the rear of the linksys to verify the connection. Check, reseat ALL cables. If it's connected to the ISP modem, can you use a Ethernet cable on the Linksys to the computer to verify signal? It may be bad, hard to say for sure.
Feb 14, 2013 | Linksys Wireless-G WRT54GX Router...
Power supply
The power supply is built in to the 'power cord'. On most consumer routers there is a transformer and rectifier built in to the wall plug. The cord that connects to the device carries low voltage DC current to the electronics inside the router case that has all of the other RJ-45 sockets, indicator lights and antennas.
Search ebay for your router and include the words power supply.
Aug 26, 2012 | Linksys Wireless-G WRT54G Router
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
I have the Linksys Wireless-G WRT54GS Router and when i plug it into my modem, no lights come on, besides the power light which was already lit. I've tried resetting it (holding the reset button for 30...
There is another way to reset the router called hard reset..
you need to hold down the reset button for 45 seconds while its turned ON and don't let it go.
After first 15 seconds, take the power cable out but still keep holding down the reset.
After second 15 seconds, insert the power cable back in but still keep holding down reset.
After last 15 seconds, release reset and turn off the router for 30 seconds.
0-15 = Power ON, Reset button Pressed in
15-30= Power OFF, Reset still Pressed in
30-45= Power ON, Reset still Pressed in
If it still doesn't work then you got a bad router, can't be fixed. :-(
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
Hi, a mouse chewed my power supply cord of my Linksys router 54GS v6. It has a transformer with 12V 500ma. Can I use a substitute transformer having 16V 500ma?? Thank you. Gary
I would not suggest that this would be safe, as the extra voltage will put a strain on the components in the router, and although it may work for a little while I am sure that it will eventually break down... it could potentially get hot enough to cause serious damage and even catch fire, so I would avoid using a higher voltage/current adapter.
Nov 08, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys wireless router shows it is connected, but I can't get onto any sites, why?
See if you can get to the router itself:
1. open a browser 2. go to 192.168.1.254
If you can get to the router, try bypassing the router and see if you can access the internet directly.
If you can, and the router is functioning properly (all lights on, etc) unplug the power cord - plug all your network cables in - plug the power cord back in. This will reset your router. See if you can get to a site now.
Nov 05, 2010 | Linksys Wireless-G Broadband Router
Cannot connect to internet Model WRT54GS
Hi
I would like to know who is your internet service provider and would like to check if the router is configured with your ISP modem.
To configure for different ISPs here is the link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US/Layout&cid=1166859761879&pagename=Linksys/Common/VisitorWrapper&lid=6187977881B11
The links are there for setting up with DSL as well as cable modem. Do let me know if its working or not.
Thank you
Rakesh
Jan 06, 2009 | Linksys Wireless-G Broadband Router
Unable to get the linksys to work.When I plug in the wires the first light doesn't come on. stays unlighted.
Open out a paper clip, on the back of the router is a tiny button marked "reset".
Pull the power cord out of the back of the router, now using three hands, one to hold the router, one to hold down the little button switch (with the opened out paper clip) and the third hand to plug the power cord back in.
Push the button in, put the power cord back in and keep holding the button down for ten to twenty seconds.
This will set your router back to the factory defaults, if the power lamp or any of the other lamps dont light up you will either have to return the unit to Linksys or if you can access the routers setup page you can do a firmware update.
Jul 24, 2008 | Linksys Wireless-G Broadband Router
Loosing linksys Router instructed cd to set up
Have had many time problems with the router:
Do the following: If you have a router and a linksys modem do it to both.
Disconnect the power source from the router and disconnect the ethernet cable wait about 30 seconds .. plug back in the power sources (do not just pull the plug that goes into the wall...... remove the black little cord that plugs into the router)
In some cases (if the above doesn't work the first time..) you may also want to completely unscrew the coaxial cable from your broadband provider ) and wait 30 seconds or a minute and follow through with the unplug resetting..
Note: there are also reset features on the back of your modem and router.. it never hurts to use those once in awhile
on router.. there little button that pops out in the back .. just hold it in for 2 0r 3 seconds and release..
on modem... SEE that tiny little hole between the power supply and the ethernet plug.. carefully insert a paper clip into the hole..no you won't get electrocuted.. and GENTLY push the reset ...
Hope this helps.
walrus4425
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
