Cannot find manual, the water collection pan is tricky, not sure what position it should be in to work correctly, it cycles on a and off does not seem to be pulling oater from a moisture issue I have in the finished basement. OLD MODEL 5548, still seems to work well as far as running and cycling.
  • 43,501 Answers
If you have it running and it is cycling on and off then the refrigerant part is trying to work but is no longer working correctly and causing the water to condensate on the coil...
The most probable scenario is that the unit hs developed a small refrigerant leak and so the unit is not cooling properly anymore...
To fix this would be more costly then buying a new unit..
That is what I would do at this point.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 30, 2011
Why does ice collect at bottom of freezer?
The freezer has the only coil in the unit that gets cold. IT does build up with ice. The unit has a defrost heater that comes on to melt the ice. The water from this process is supposed to drain down a tube into the bottom pan that you cannot se under the unit. IF the tube is plugged with ice or other debris, the water from the defrost cycle cannot drain correctly and runs into the bottom of the freezer. There is quit a bit of work involved in getting this to work again.
Jul 18, 2014 | Whirlpool Refrigerators
My split air conditioner,s compressor is not starting , whtat to do?
Check for obvious things like a blown fuse or open service switch near the condenser unit (the outside part). Make sure that power (most of these are 240V) is available to the unit. Please, do not work on live electrical equipment unless you are 100% sure of what you are doing. You don't get a second chance at these voltages.
On the thermostat, make sure the mode switch is set for cooling, the fan switch is set to on or auto and the temperature set point is set below the current room temperature. If a programmable type thermostat, make sure the time, date, and program are correct; or override to manual mode so that your settings are followed. Check the air handler to make sure that filters are not clogged with dust and dirt - if they are the unit may have iced over the cooling coils. If this has happened, replace the filters and allow time for the ice to melt off the coils. Many air handlers have large, shallow pans installed under them when located above a living space. This is to collect condensate that leaks out of the unit. A pipe will be connected to the pan to allow the pan to drain this condensate off to the outdoors. If the pan is full of water, the drain pipe is clogged and will need to be snaked clear to empty. Locate the float switch. The float switch monitors the water level of the pan, so once it is empty - the switch float arm should be resting on the pan floor - not in the up position (which prevents the unit from starting).
These are the most common home-owner correctable issues that will prevent a unit from starting - there are many others that require advanced skills and equipment to detect and correct. Some of these are: low refrigerant gas, bad motor, bad start / run capacitor, bad relay coils, bad transformer, bad thermostat, the list goes on and on.
If all these items listed above are ok, the unit should attempt to start. If the unit still will not start or buzzing sound is heard professional service is likely required.
Aug 20, 2012 | Air Tools & Compressors
I need an owners manual for a Haier HWF05XC7-2
Do not add water to the pan under the air conditioner. Water may collect in the pan and could overflow the pan in some conditions. If you add water, you are more likely to have water spill from the pan. Air conditioners like this work by refrigeration. As the air cools, the air can't hold as much water and this condenses into the pan.
The user manual for the HWF05XC7-2 is available from Sears Parts Direct on the product support page: http://www.searspartsdirect.com/partsdirect/user-manuals/HWF05XC7-HAIER-AIR%20CONDITIONER-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0808288.pdf . Note: the manual covers two models, HWF05XC7 and HWF05XC7-2.
I hope this helps.
Jun 15, 2017 | Haier Heating & Cooling
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
There is water coming from under the refrig. The overfill water pan is full that is under the freezer. The ice maker is working and so is the water dispenser. The coils are really dusty could this cause...
The overflow pan is the water that is collected during the AUTO DEFROST and usually the water evaporates off before the next defrost cycle. so if there is overflow of water on the collection tank , then the thermostat must be kept a little lower to reduce more frosting.
Jan 18, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I want to know about the water getting stored at back of the fridge SAMSUNGRT35EBUX1/XTL model. the copper tubes are immersed in water which is in the back side of the right bottom tray, DO i need to...
No you do not need to remove the water, this is the collected water from the defrost cycle of your refrigerator and it is totally normal. the copper tubes are actually part of your refrigeration system and are routed through the water for two reasons, one is to dissipate heat from the condenser unit and the other is to help evaporate the drain water. The condenser fan located under your fridge does the rest of the work as far as evaporating the water.
So the short version. The water is supposed to collect there.
You do not and should not have to worry about ever emptying the pan.
Let me know if you have any other questions!
Thanks!
Aug 17, 2010 | Samsung Refrigerators
Water is draining into a pan under the refrigerator, once in a while
When the fridge defrosts, the water (melted ice) is collected into the water pan. Empty it when the fridge compressor is ON.
Oct 07, 2009 | Kenmore Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Water in box waqter keeps accumulating on shelves iveg bins andunder bins
When the freezer goes through the defrost cycle, the water collects in the defrost drain pan and drains into a pan underneath the unit where it evaporates over time. If the defrost drain pan is clogged, the water will fill the pan where it will freeze. Once the pan is full of ice, the water from the defrost cycle will run over the pan and down into the fresh food section. This will require that the drain pan be clean of the ice and the drain tube cleared of ice and debris.
Hope this helps.
Aug 07, 2009 | Whirlpool Refrigerators
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
