Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have an 8yo KitchenAid Side by Side and it's occasionally leaking water from the lower part of the freezer. After removing the lowest bin, there was a sheet of ice on the 'floor' of the freezer. Everything seems to be working fine. Thanks for any help/advice you can offer.
    President:
  • 2,468 Answers
The drain tube for defrost has plugged behind the rear panel and needs to be cleared of debris
Posted on Mar 30, 2011
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Water is leaking from an opening in the back surface of the freezer compartment and forming a puddle that freezes and then melts, dripping under the freezer door
If you remove the shelves and bins from the lower section of the freezer you will notice in the back of the freezer your drain pan is clogged. Turn off the freezer and use a turkey baster to add hot water to the pan until you clear the clog. This can happen when foreign object slow the water leaving the freezer during defrost and cause it to refreeze stop water from leaving the freezer. Not a big problem or difficult repair. Just clear the drain and remove all the ice from the drain pan. Could take 15 mins or so to complete this..
I hope this helps
Jul 26, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Oct 27, 2008 | KitchenAid KSBP25FKSS Side by Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Sep 11, 2007 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
146 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
