Question about Canon DR9050C
Scanner runs loud not smooth - Canon DR9050C
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have many years experience with Canon scanners and I do have some suggestions for you.
The only time I really experienced a loud scanner in that model was if if the rollers the smaller black ones were not spinning freely causing the paper to drag to the machine. That usually was caused by a gunked up bronze bushing the rollers sit in. When you open up the top half of the scanner by raising it up and with the power to the scanner turned completely off. You should be able to spin the small black rollers freely by hand by just passing your hand over each one. They are mounted on a shaft and and each set of 4 or 5 black rollers are mounted to a single shaft.Try spinning them if they all spin freely then your problem is with the lower rollers.
Again with power completely off try pushing on the black rollers on the bottom by hand. You will feel some resistance with these rollers because there are gears mounted to the end of these shafts and they are belt driven. They wont spin as freely but should spin with some resistance and if it is the problem your having with loudness you should here sort of a metal on metal sound that is telling you one of the bushings is worn out. If you dont hear any sounds then your problem is probably with the main drive motor that propels these rollers. To get at that motor you will need to remove the back cover first and then the right hand side cover because the motor is on the right hand side as you are facing the machine as if you were going to use it. The fix can be as simple as readjusting the tension on the main drive belt by loosing the screws on the main drive motor pulling the motor back until you have more tension on the belt and then tightening the screws back on the motor. Or it can be the motor itself. You will have to remove the screws that hold it in place and then slide remove the belt and slide the motor out towards you. You will recognize this motor because its towards the back of the machine, silver in color, with one small electrical connector mounted to it and its round about 3 to 4 inches in diameter. Once the motor is out try spinning it by hand to see if it is binding. Also once it is out now try spinning the bottom rollers by hand to see if you get a metal on metal sound because they will spin much more freely now. Once you determine which one of the items is causing your loud noise then contact your local canon dealer for the replacement part or you can even try looking on Ebay there are many parts for sale for your scanner its a popular model still today.
I hope this helped you out and if not let me know.
Posted on Apr 01, 2011
Model glxi96, cant drive smoothly i think big clearance of differential, is there be adjustment for that like old models of differential?
the play in the side gears of a differential has little to do with driving smoothly. If there is a problem in the differential then there will be a loud howl or a grumble on drive or overdrive. If it doesn't drive smoothly then run the fault codes to check for TCM and other electronic problems. Check/change the oil and have the bands and clutch packs adjusted . These are the sort of items that will not allow it to drive smoothly.
Jul 11, 2014 | Mitsubishi Mirage Cars & Trucks
STARTS ROUGH,LOUD NOISE FROM ENGINE,THEN RUNS SMOOTH
It sounds as though you may have a starter bendix failing or the starter bolts may have loosened. Disconnect the battery, crawl under and investigate.
If the bolts are tight, you may want to look into the cost of a new starter.
Good luck
Apr 03, 2014 | 1999 Chevrolet Silverado 1500
2001 mazda tribute
I would replace the engine and transmission mounts, they are hard and transmitting engine vibration to the chassis.
Feb 28, 2014 | Cars & Trucks
New AC makes loud noise
I would call contractor back
Jun 13, 2013 | Heating & Cooling
Am looking for installation CD drivers for Benq S2W3300u scanner.
Hi ,
You will find the driver here : http://downloadnew.org/software/benq-s2w-3300u-scanner-drivers/
Download it and install it . Your scanner will run smooth .
Regards .
Jan 28, 2011 | BenQ S2W 5300U Color Scanner
My 91 oldsmobile 98 runs rough in idle but when driving run smooth.
Rough idle is a very common problem on 4 cylinders, but I believe the 98 Regency has a 6 cylinder in it, right?
Sometimes the coil packs get iffy, and sometimes the EGR Valve gets a leak in it causing a rough idle.
When the accelerator pedal is depressed, it can change things so that the engine seems to run smoothly.
However, I would look for codes to see if anything intermittent is occurring in the engine that may need attention.
The OBD-I scanner can help to diagnose the problem, if anything is out of specifications on the engine in question.
The owner will have to find a technician that has such a scanner.
Aug 29, 2010 | 1991 Oldsmobile Ninety Eight Regency
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Loud niose from centre of manafold motor run nice & smooth ?
on the 302 you can not see the cam and lifters unless you remove the manifold. did you try removing the distributer and turning the oil pump shaft until the light in the dash goes out? that will drive oil to the upper cylinder assemblies, other than that you may be looking at replaceing some damaged bearings and or camshaft.
Apr 03, 2009 | 1978 Ford Granada
Canon DR9050C Logo
192 people viewed this question
old marine
old marine
