Connections I recently purchased a Philips DVDR3505/37. I need to connect it to a GOVIDEO DDV9550 (Dual-Deck Recorder), a SONY Triniton 12-year old TV, and soon to an HDTV converter box. I have the manuals for the first 3; what I don't have are enough input/output jacks on either TV or VCR to add the DVDR. I do have the DVDR outputs connected to the VCR inputs, and that works fine -- but apparently I need to find inputs for antenna and the recording aspect of the DVDR -- which has an HDTV compatible tuner. Please tell me if what I want to do is possible, and HOW??
  • EACIII Aug 05, 2008
    bbtoast: I don't have cable, just an old-fashioned antenna. Suggestions? EACIII
  • EACIII Aug 06, 2008
    Brian: I have an ordinary indoor antenna -- a version of 'rabbit ears'. I know that sounds like 1950s primitive, but I'm an ancient codger who still works 60 hrs/week, tapes a few broadcast things to watch at my convenience, and probably spends more time watching things from a massive 4k hour video collection. So -- do I buy a separate antenna for DVDR, or is there a simple way to split the current one, which is attached to VCR? Thanks for your help!
  • 319 Answers
I believe that you simply need a splitter from your cable line from the wall to the items that need it.
That will give you input to the DVD-R and to the Cable box.
Let me know if we need to discuss further, I will be glad to help!
Brian
Posted on Aug 04, 2008
  • Brian Berndt
    Brian Berndt Aug 05, 2008
    OK, what type of line comes into the house from the antenna?
    You should be able to split it, and have the ANT in to any HD Signal Tuner.
    That way you will enjoy the signal at either component!
    Also, I would not think that you would need to purchase an HDTV converter box....you could use the DVD's tuner as your main tuner all the time....whether you are recording or not.
    Let me know if this makes sense!
    Brian
  • Brian Berndt
    Brian Berndt Aug 06, 2008
    OK, I get it!
    You could go either way, new rabbit ears or you could simply wire in the new unit.
    The antenna function relies simply on metal on metal. Your new device will probably have a one-pin receiver "coaxial" input. VCR's would commonly arrive with a push in one of these. If you have these type of cables from your rabbit ears, you can get a simple coaxial splitter which are commonly used to install cable systems.
    So you can go from Rabbit Ears to line from rabbit ears to a splitter then to each receiver that needs a line from the rabbit ears.
    Will work, no prob!
    If you need splitters, etc, Radio Shack or even Target should have all you need!
    Good Luck and regards!
    Brian
Vcr won't record
first try a new set of connecting wires these are the usually cheap wires that will give out easily. if that don't work ,its most likly gonna be the tape recorder itself. how old is it.
Jan 21, 2012 | GoVideo DV1130 DVD Player/VCR
I need a new remote for my dual-deck vcr serial #133200120221. I need to purchase a new one asap.
Remote Controls are often model specific. If you can perhaps post back exact model number?
Alternately, pls try and inquire from:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | GoVideo Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox VCR/CD player will not come on. It is
I have purchased a new VCR/CD player. I tried everything, but nothing worked. I did purchase another Magnavox, but if this machine does not perform any longer than the first one, I will not purchase another one. The reason I purchased a Magnavox this time was that there were no other products available in my town.
Aug 26, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Mar 11, 2009 | LG DR787T DVD Recorder
DVD Recorder VCR combo, VCR will stop after 23 sec of play or rec
necesito saber que tecla presiono para desactivar el modo progresivo scan
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR Deck not working
i found a website that explained what was wrong and how to fix.
Jan 06, 2009 | GoVideo Televison & Video
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
