Question about Denon DP-47F Turntable
The tonearm on my Denon DP-60L will not drop - Denon DP-47F Turntable
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Headshell for Denon DP-45F Turntable
Any Half-Inch / Standard mount headshell will work on this turntable. Luckily for you, these are very common.
- Davis
DJ Pro Audio
www.repairnyc.com
Posted on Aug 08, 2008
maklean
  • 1665 Answers
SOURCE: Denon DP52F tonearm tube is turning freely
You must raise top cover to have acces to arm support shaft and tighten holding nut.
Posted on Sep 14, 2008
  • 444 Answers
SOURCE: Denon DP- 60L Tonearm bearings are loose, How should I adjust them..?
They can not be adjusted, Turn table has obvisily been abuse,Just buy a different one, End don,t abuse it,
Posted on Nov 02, 2012
Why does tonearm drop in middle of record instead of start of record
It thinks it's a 45 rpm. There is a trip lever near the edge of a 33rpm record on the turntable that may not be working properly.
Jun 14, 2014 | Denon DP-300F Turntable
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
Nov 02, 2012 | Denon Audio Players & Recorders
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Turntable speed erratic
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Jan 01, 2009 | Denon DP-47F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Aug 02, 2008 | Audio Players & Recorders
Denon DP-47F Turntable Logo
109 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
