Question about VinoTemp (VT60GNV) Wine Cooler
Vinotemp VT-52SN motor runs continuously but will not cool below 69 degrees.
projdoc
  • 2237 Answers
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Posted on Aug 26, 2009
SOURCE: Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Posted on Sep 04, 2008
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
57 varieties
  • 1653 Answers
SOURCE: Vinotemp (VT-60), cools, but doesn't turn off
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Posted on Nov 05, 2009
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
Vinotemp not staying cool, it's set at 54 degrees, but it's at 82 degrees
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20.
First, unplug the wine cooler and take off the back panel. The back panel is held into place with several philips head screws.
Step 2:
Locate the compressor. You'll find the compressor in the bottom left corner of the VT-60 as viewed from the back. You will see copper tubes coming out of the compressor. These tubes carry the compressed refrigerant to the evaporator assembly. Be careful not to crimp or damage the copper tubing.
Step 3:
Find the black plastic cover to the left of the compressor. This cover is held into place with one philips head screw. Remove the screw and remove the cover to find the PTC start relay.
Step 4:
The replay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Slide the relay on the connector pins, reattach the blade connector, reattach the black pastic cover over the relay, reattach the back panel onto the VT-60 and you're done.
Sep 09, 2011 | VinoTemp VT-60 Wine Cooler
My Vinotemp VT52SN stopped cooling. I was away from home for a few days and when I came back the fan was running and the temp was stuck at 62 degrees. I had it set at 54 (and lower)... the fan runs and I...
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Jul 08, 2011 | VinoTemp VT-52SN Stainless Steel Wine...
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Cools, but not below 60 degrees
It sounds as though you may have to replace the cooling system on the unit, to order it you can call Vinotemp @ 800-777-8466
Apr 18, 2009 | Refrigerators
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
135 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
