Question about Maytag EPIC MFW9700S Front Load Washer
Won't spin It washes fine but won't spin. If you go straight to spin cycle it still won't spin. There are 5 towels, I moved them around....nothing. Unplugged it for ten minutes re washed and when it got to spin cycle no spin. Help!
    Problem Solver:
  • 3 Answers
Won't spin
Posted on Aug 23, 2009
    Problem Solver:
  • 16 Answers
I agree with Barry, also check carbons and try on spin cycle without any load
Posted on Oct 29, 2012
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
  • 3463 Answers
SOURCE: Bosch Nexxt 800 washer won't drain clothes fully
U shud be able to select spin only, I would check the filter if I wer u.
It shud be located behind removable lower front panel.
Plz rate my solution.
Posted on Dec 31, 2008
  • 209 Answers
SOURCE: bosch max wfl2000 washing machine
I am a recently retired appliance engineer of 20 years sounds like a faulty cold supply, or just no water getting to machine, if water supply ok check the water solenoid, check for open circuit just try that to start with, hope this helps if so rate me please
Posted on Sep 09, 2007
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
  • 53 Answers
SOURCE: When I wash towels they are soak when the cycle is
I have a GE front loader and this problem drove me nuts after spending $$$$ and having this problem only after 2 years of operations! Please check the filter screen. Remove the screws that hold the front panel to the body. There will be water coming out, so have some towels and a pan to collect. Once the panel is removed, there is a knob for the filter screen which needs to be turned to remove. Have your pan ready because it will leak. You can clean the screen by hand removing the gunk (keep the money for your efforts, however :)) Replace the filter, turn to tighten, replace the front panel and screws and run the washer through a short cycle to check out everything and make certain there are no leaks before you walk away. Good Luck!
Posted on Mar 07, 2010
My Defy Automaid DAW285 only works when you put in a small load of washing
It seems that the "start" winding of the motor is defective or the capacitor is defective
Nov 15, 2011 | Washing Machines
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 09, 2011 | LG Washing Machines
Neptune tl washer will go half way threw cyle,start to spin,stop and start to spin,stop and start to spin .tried to unplug it restart and nothin, tried different settings still nothing. tried moving the...
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If it one of those machines I suspect a possible clutch malfunction.
See this post for what is involved to do clutch maintenance or replacement.
Do you have any error codes to the display if it's a FAV6800A such as dC or uC unbalance codes. Is the wash tub banging around on Spin Cycle of the Wash Cycle? ……Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Apr 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not go through spin cycle
it sounds like it could be the lid switch malfunctioning. the part should look something like this. d668319.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Jul 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
2,124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
