Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Makes a clanging noise when it stops running - Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
    President:
  • 2,468 Answers
It has to be the compressor and has come loose on its rubber mounts and as the motor stops the internals of the compressor strike the side of the compressor body and produce this noise,tighten the rubber mounts on that compressor and it should be fine
Posted on Mar 30, 2011
GE washer makes clanging sound during wash cycle
What is the model number of the unit?
Nov 02, 2012 | Washing Machines
I hit a stone and now the engine clater
THE MOWER MIGHT BE OUT OF TIME. REPLACE THE BLADE. CHECK THE WOODRUFF KEY INBETWEEN THE PROPELLAR SHAFT. IF ITS BENT REPLACE IT. ALSO CHECK THE TOP END OF THE PROP SHAFT FOR ANY MISS ALIGNMENT. IT SOUNDS LIKE THE ROCK IMPACT MADE SOMETHING LOOSE IN THERE>
Jul 25, 2012 | Poulan Pro " Pro" Self Propelled Mower
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
On my 2000 blazer. every time i hit the gas pedal i here a clanging noise, and if i hit the breaks hard i here the same clanging noise. what could this be??
Sounds like something loose is swinging with the stop and go momentum. Look underneath for something loose, like exhaust. Have someone listen close by while you drive it slow in forward and reverse, to try to pin point it.
Jul 31, 2009 | 2000 Chevrolet Blazer
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this
need a new fan blade. might want to check out your local wholesale parts store. make sure you take unit model # and s#
May 23, 2009 | Haier (HPE09XC6) Air Conditioner
Clanging sound when i accellerate
Sounds like a transmission mouting is worn
Apr 28, 2009 | 1997 Saab 900
Loud noise
When the compressor stops, the movements of the internal components are normally absorbed by the internal spring supports. If a spring breaks, etc., the inner moving part will contact the outer case and give a knocking noise or two when it stops. You can make the compressor (even a new one) do this by giving it a shake. The compressor will most likely run for years this way with no performance problems. It is rather expensive to replace a compressor, (especially for only a noise issue) so most people just live with it or get a new refrig and use their old one as a second refrig in a basement or where ever. Please don't bother to rate this, as anything but a Fix-Ya drops my score.
Dec 31, 2008 | Whirlpool Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
225 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
