Question about IBM Lenovo ThinkPad T400 7417 Notebook
Lenovo t400 cannot boot. have "z" light only - IBM Lenovo ThinkPad T400 7417 Notebook
    Guru:
  • 868 Answers
Hi vincent,
I see that you have a "z" light indicator on the system when powered ON but you see no video on the screen.
The "z" Indicator means that the system is turned ON and ready to use but is in standby mode.
To disable standby mode on your system simply press the FN button for about 5 seconds on the system make sure that the machine is turned ON, this will make you system go back to normal mode.
Note:
For additional info on the issue the system can be put to standby mode by holding down the FN+F4 for a second or two this will enable standby mode on your Thinpad T400 and to disable the standbymode press and hold down FN for 5 seconds.
I hope that this will be of help regarding you concern, have a nice day.
Posted on Apr 09, 2011
Joed911
  • 4338 Answers
SOURCE: Lenovo T400 web camera
Great!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 15, 2009
SOURCE: How to Enable integrated camera in lenovo T400
  • start,
  • control panel,
  • system,
  • hardware tab,
  • devices and right click on web cam and chose enable.
hope this helps.
Posted on Aug 15, 2009
SOURCE: my lenovo T400 will not shut down even when all
Hi guest, try to turn off the pc by using the power button. Then remove the cables and battery on the laptop. Then push & hold the power button for 5 seconds. Reinsert the cables and battery then turn on the pc.
Check if you will be able to shut down your pc using the operating system..
Posted on May 17, 2010
SOURCE: my lenovo T400 will not start up
I got the same problem. Have u resolved the it? If so, please send a message to: tjsteen@broadpark.no
Posted on Oct 22, 2010
  • 2567 Answers
SOURCE: my lenovo t400 has screen flickering when ever i
Sounds like a problem with the video adapter chip. The chip might be either defective or experiencing bad connection with the motherboard. In order to fix this problem, you will need to disassemble the notebook, pull out the motherboard & inspect the video chip & its connection points to the motherboard. If the video chip is defective, you might have to replace the motherboard.
Posted on Apr 10, 2011
My lenovo T400 will not start up. The computer is plugged in.The battery and plug indicator lights are both green. When I push the on / off button the 2 indicator lights that are shaped like...
A less frequent situation that can happen in a laptop resulting in it not booting up is a damaged USB port. If the pins are touching the system will not start up. You can fix this problem by using a small flat blade screw driver, tweezers or micro needle nose pliers to carefully separate and reform the contacts so they do not touch.
This is not a permanent fix because the USB port will become unusable. To fully fix it would require you to replace the system board, which may or may not be covered under your warrenty.
Jun 01, 2013 | Lenovo ThinkPad T400 - Intel Centrino 2...
My lenovo t400 has screen flickering when ever i on the laptop flickers continously booting stops left side some part of screen goes light blue
Apr 10, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
I accidentally spilled water in my Lenova T400 Laptop. Its stopped and now its not booting up. Any help will be appreciated
Water and laptops don't mix.l That's a shame. And, many extended warranty agreements will not cover such an accident.
Feb 04, 2011 | Lenovo ThinkPad T400 - Intel Centrino 2...
How do I start my Lenovo T400 in safe mode?
Just keep on pressing F8 during system startup. It will land you to a Windows with Safe Boot as first option.
just press Enter.
That's it.
Jan 19, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
Great!
Thanks, Joe
May 14, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
IBM Lenovo ThinkPad T400 7417 Notebook Logo
3,116 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
